Re: 3VZE leaking valve covers
It's a common problem with the 3VE heads, so I'm told. You could try using
a slightly shorter bolt.
"RAW" <nospam_wolford@ispwest.com> wrote in message
news:e8a6320e46@enews3.newsguy.com...[color=blue]
> Same problem with two sets of heads. First with new gasket job, then with
> new rebuilt engine. The only thing not changed was the covers.
> "Joseph Wind" <jpg@gif.com.invalid> wrote in message
> news:AaIpg.4484$EJ3.3327@trnddc06...[color=green]
>>I was told it's a sign of a warped head. Has the engine overheated from a
>>leaky radiator, before?
>> news:e84tme012a3@enews2.newsguy.com...[color=darkred]
>>>I have a '91 4runner.
>>> I've been trying to get the valve covers to quit leaking. Yes I've even
>>> used new gaskets with form a gasket put to key areas.
>>> Still leaking.
>>> I had the heads off and it looks like the problem is that at each bolt,
>>> there is a metal sleeve that keeps you from running the covers down
>>> tight on the gaskets.
>>> Is it possible that the sleeves have allowed the covers to "raise" up a
>>> little. Causing the problem.
>>> Is this a known problem?
>>> If so what is the fix??
>>> Thanks
>>> RAW
>>>[/color]
>>[/color]
>[/color]
