lower control arm toytoa truck - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-01-2006, 08:51 PM   #1 (permalink)
delow01
Guest
Posts: n/a
View delow01's Photo Gallery
Can someone please tell me why I can not remove the rear bolt from both lower
control arms in a 1988 toytoa truck?
I remove the front bolts like butter then after using a 5lb hammer on the
rear and removing the lower ball joint I can not get the back to move out,
but can get them to move a little left or right by lifting/lowering the
control arm.
I have tryed for hours with no luck-Any ID,s ?
Old 07-02-2006, 11:24 AM   #2 (permalink)
edokamoto@netzero.net
Guest
Posts: n/a
View edokamoto@netzero.net's Photo Gallery
Re: lower control arm toytoa truck
I have a 89 pickup standard bed 2 wheel drive. The torsion bar is
attached to the lower control arm isn't it. The bar replaces a coil
spring and pulls down the lower control arm. You should put the lower
control arm bolts back in so nothing flies out and then loosen the bolt
and locknut that pushes on the little arm that pushes on the torsion
bar to release tension on it. Once all the tension is gone you can
remove torsion bar by putting a vice grip on it and hammering it off.
Then remove lower control arm bolts.
delow01 wrote:[color=blue]
> control arm.
> I have tryed for hours with no luck-Any ID,s ?[/color]
Old 07-02-2006, 01:46 PM   #3 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
On 2 Jul 2006 08:24:02 -0700, [email]edokamoto@netzero.net[/email] wrote:
[color=blue]
>Then remove lower control arm bolts.[/color]
Yes you must unload the Tbars and remove them. Ait tools are big help
with stubborn bolts as the vibration the set up in the bolt can help
free then when rusted.
[color=blue]
>delow01 wrote:[color=green]
>> control arm.
>> I have tryed for hours with no luck-Any ID,s ?[/color][/color]
The SnoMan
[url]www.thesnoman.com[/url]
BB code is Off
Smilies are Off
[IMG] code is Off
'97 Avalon Rear Control Arm Bushings Went Bad!!! parimento1 1st Generation (1995-1999) 7 04-10-2006 04:30 PM
Control Arm Bushings 98 Avalon Camry & Solara Lounge 5 11-03-2005 09:49 PM
