Rear differential driveshaft seal - Quick Question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-04-2006, 06:31 PM   #1 (permalink)
nobody
Guest
Posts: n/a
View nobody's Photo Gallery
I had to replace the input drive shaft oil seal in my differential
(1984 4x4 Toy Pickup).
The question is how tight should I torque the large nut that holds the
companion flange and "U" joint bracket.
Any information is greatly appreciated!
Nick
Old 07-04-2006, 10:36 PM   #2 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
Re: Rear differential driveshaft seal - Quick Question
On Tue, 04 Jul 2006 17:31:59 -0500, nobody <somewhere@nowhere.com>
wrote:
[color=blue]
>Nick[/color]
Oh boy, you kinda screwed the pooch here. The best way to do this it
to mark the nut and oinion stub BEFORE you remove nut and retighten
to same spot. Lacking this, you need to tightened it to get proper
preload in term of in lbs of toruge required to rotate it which is
tuff to do properly with diff installed.
The SnoMan
[url]www.thesnoman.com[/url]
BB code is Off
Smilies are Off
[IMG] code is Off
Rear Oil Seal. victor Camry & Solara Lounge 9 04-29-2005 01:13 AM
Rear Disc brake axle question tr0ublemaker03 Yaris, Vitz and Echo Forum 0 07-07-2004 10:24 PM
