86 1T 22RE Auto - Starting Problems Again - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-05-2006, 09:14 AM   #1 (permalink)
Kevin
Guest
Posts: n/a
View Kevin's Photo Gallery
Hi,
Three years ago I had to fight this, now it is back (or it just hasn't
happened very much that I can remember).
I sometimes get a half second or so delay after moving the key to the
start position before it cranks. The other day it wouldn't even crank
a couple of times; I waited a minute or so and then it cranked (delay
still there). I have replaced the starter, battery, and cables a
number of times over the last few years. It is almost as if the
weather has something to do with this; the hotter it is, the worse it
is.
I have read some threads about the ignition switch, but didn't see one
about a delay. Could a bad ignition switch cause this problem? I'm
thinking of just picking one up to see if this fixes it. I have tried
everything else.
TIA,
Kevin
Old 07-05-2006, 01:46 PM   #2 (permalink)
William Brown
Guest
Posts: n/a
View William Brown's Photo Gallery
Re: 86 1T 22RE Auto - Starting Problems Again
Hey!
Try replacing or cleaning the starter relay.
Bill
"Kevin" <kreynolds@aviagen.com> wrote in message
news:1152105241.778277.164530@p79g2000cwp.googlegroups.com...[color=blue]
> Hi,
> is.
> everything else.
> TIA,
> Kevin
>[/color]
Old 07-06-2006, 01:07 PM   #3 (permalink)
Kevin
Guest
Posts: n/a
I didn't think this one had a relay... I'll check the schematics
tonight.
I hate to fork out $75 unless I'm sure it is the starter switch. Guess
I'll try to check voltage on the solenoid if I can get a "hard"
failure. In the meantime, I guess a wire to the battery will keep me
in business.
William Brown wrote:[color=blue]
> Hey!
> Bill
> news:1152105241.778277.164530@p79g2000cwp.googlegroups.com...[color=green]
> > Hi,
> > is.
> > everything else.
> > TIA,
> > Kevin
> >[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
1989 Toyota Pickup 22RE - Intermittent Starting Problem Gabriano 89-95 Toyota Pickup/Hilux 12 08-05-2009 08:44 AM
89 auto problems Twisted Sid Supra Forum 5 03-01-2006 06:30 PM
starting problems when hot 2000 corolla cee710 Archived Corolla threads 14 04-05-2005 05:42 PM
Starting problems ecu rebuilt..update... HeathRocksLA@ya T-100 0 03-21-2005 04:02 PM
Starting problems. Please help. sadik Camry & Solara Lounge 6 09-05-2002 01:02 PM
