98 tacoma problem after sitting parked for weeks - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-06-2006, 12:47 PM   #1 (permalink)
mDunbar
Guest
Posts: n/a
View mDunbar's Photo Gallery
I recently went away for business and left my '98 Tacoma V6 4x4 5spd
parked for 2.5 weeks.
Upon returning I started it up, all seemed fine. I put it in reverse
and started to release the clutch pedal and there was resistance.
Almost as if the brake calipers had all seized up. I tried it again
reving the engine to 4000 RPM and releasing the clutch further. Then
the car jolted backwards, apparently breaking free. Since then I have
driven about 100 miles no problem.
Is this more likely a brake problem or some kind of drivetrain problem?
Should I be concerned?
The truck has 130k miles, I have owned it since 70k miles. As far as
oil, I only change the engine oil regularly. What other areas on the
drivetrain need oil replacement for a manual transmission?
Thanks in advance,
Matt
Old 07-06-2006, 04:41 PM   #2 (permalink)
Andy Hill
Guest
Posts: n/a
View Andy Hill's Photo Gallery
Re: 98 tacoma problem after sitting parked for weeks
"mDunbar" <matthew.dunbar@gmail.com> wrote:[color=blue]
>[/color]
Did you have the parking brake set while it was sitting? If so, brakes sound
like a reasonable suspect. Otherwise not.
At the very least, the differentials and transfer case fluids need to be changed
(roughly every 30K miles). Lots of lube points that normally appreciate a bit
of grease, too. Even the cheapie Haynes / Chilton manuals will give you the
lube schedule and procedures.
Old 07-08-2006, 03:03 AM   #3 (permalink)
Jodabo
Guest
Posts: n/a
View Jodabo's Photo Gallery
Sounds like the park brake has seized probably a mix of moisture and
pressure and time nothing to worry about if all drives well.
Joe
"mDunbar" <matthew.dunbar@gmail.com> wrote in message
news:1152204441.726049.218750@b68g2000cwa.googlegroups.com...[color=blue]
> Thanks in advance,
> Matt
>[/color]
Old 07-08-2006, 11:35 AM   #4 (permalink)
M. Cantera
Guest
Posts: n/a
View M. Cantera's Photo Gallery
You got rust on the disks and that causes some break pads to stick to
the surface of the disks. You may also have corroded and pitted
pistons in your brake calipers.
You need to read the owner's manual. since you don't meniton
replacing the brake fluid every two years (along with the coolant)
On 6 Jul 2006 09:47:22 -0700, "mDunbar" <matthew.dunbar@gmail.com>
wrote:
[color=blue]
>Thanks in advance,
>Matt[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
98 Tacoma problem!!! co1124 1st Generation (1995.5–2004) 8 02-16-2006 10:40 PM
Problem with 98 Corolla SiUcFlYeR2006 Archived Corolla threads 2 01-09-2006 04:40 PM
98 Camry LE Problem (Odometer stuck at 0) Prophecy 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-28-2004 02:58 AM
98 Camry with exhaust problem J-Racer 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-09-2003 09:23 AM
