1995 toyota 4 runner vacumm problem. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-06-2006, 05:52 PM   #1 (permalink)
JerryG2k5
Guest
Posts: n/a
View JerryG2k5's Photo Gallery
I just had a recent head job done, due to car overheated and blew my
heads, The car is working, but its idling kind of rough and is also my
my check engine light is comming on. I had a friend of mine check it
with the diagnostic computer and its is giving me a 71 code. Its
supposed to be my EGR valve that is supposedly stuck. Is there a way to
verify if the EGR is trully stuck in an open or shut off position? or
if it is a EGR system problem and one of the hoses is in the wrong
location. If anyone can help out, it would be greatly appretiated.
Old 07-07-2006, 05:30 AM   #2 (permalink)
Joseph Wind
Guest
Posts: n/a
View Joseph Wind's Photo Gallery
Re: 1995 toyota 4 runner vacumm problem.
The EGR valve, if I'm correct, is on the rear passenger side head, covered
by the intake manifold. I was told it should be cleaned or replaced if you
were ever to remove the intake manifold/plenum. Since you had your heads
done they should have replaced it. It might still be under your warranty.
If not you'll have to remove the intake plenum.
Do a search for a shop manual for your year and model. BTW is it a 95 or 95
1/2 4Runner?
"JerryG2k5" <jerry_661@hotmail.com> wrote in message
news:1152222763.355942.51990@s53g2000cws.googlegroups.com...[color=blue]
>[/color]
Old 07-11-2006, 09:26 PM   #3 (permalink)
JerryG2k5
Guest
Posts: n/a
Thanks for the reply, but I think your thinking of the PCV valve. The
one under the intake manifold. The valve was replaced when the heads
were done with a new one as it would be hell trying to replace it after
the intake manifold was placed. The EGR valve is the one located in the
front of the intake manifold that looks like a little saucer on the
passenger side connected top a bunch of small black hoses. I am also
curious if the EGR valve malfuntioning would impede my cruise control
from working. I seriously have had bad luck with this truck, but put
too much money into it to throw in the towel just yet.
Joseph Wind wrote:[color=blue]
> 1/2 4Runner?
> news:1152222763.355942.51990@s53g2000cws.googlegroups.com...[color=green]
> >[/color][/color]
Old 07-12-2006, 02:44 AM   #4 (permalink)
Joseph Wind
Guest
Posts: n/a
Maybe your right, I have to look at my engine again, but I part your
describe is the Air Mass Meter. It has a wide rubber booted connector.
news:1152667564.323312.76120@p79g2000cwp.googlegroups.com...[color=blue]
> Joseph Wind wrote:[color=green]
>> covered
>> you
>> warranty.
>> 95
>> 1/2 4Runner?
>> news:1152222763.355942.51990@s53g2000cws.googlegroups.com...[color=darkred]
>> >[/color][/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
1989 Toyota Pickup 22RE - Intermittent Starting Problem Gabriano 89-95 Toyota Pickup/Hilux 12 08-05-2009 08:44 AM
TOYOTA - an Obsession, a Religion or just Madness? RAV4EVR General Discussion 70 02-22-2008 11:07 AM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 07:54 PM
1985 Pickup starting problem...HELP twinturbonoy Pre-88 Toyota Pickup/Hilux 10 03-15-2006 02:25 AM
