For those whose A/C only works on hi - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-07-2006, 07:48 PM   #1 (permalink)
Randy
Guest
Posts: n/a
View Randy's Photo Gallery
This is a common fix I suppose, but I was just given some great advice
here in another matter, and wanted to give something back.
My A/C was only working on the highest speed so I figured I'd need a new
motor. Turns out all I needed was a new blower resistor. My truck is a
1991 SR5 Pickup 4x4 XCab, 3L V6, but the fix is the same regardless of
the model (though the part number might be different).
Note that the Chilton manual for these trucks shows the blower resistor
in the wrong spot. It is actually a small part located in the firewall
in back of the glovebox and to the right of the blower motor (which is
directly behind the glove box). A 4-pin harness runs from the blower
motor to the blower resistor in the firewall. Just unplug the harness,
and remove the two screws holding the blower resistor. It lifts out of
the firewall easily. The backside consists of three coiled wires with a
solid bead of insulation material running inside each coil. If your A/C
is not working on the lower speeds, this material is going to be cracked
in one or more of the coils.
Toyota charges $48 for this part, but I got it from a discount Auto
Parts place in town for $32.50. For this truck the Toy part number is:
87138-89105. The Auto Parts equivalent is made by "Standard" PN RU246.
It looks identical and works great. Just in time for summer too.
The great thing about this fix is all you need is 30 seconds, 30 bucks,
and a phillips. ;) Hope this helps someone.
Old 07-07-2006, 09:27 PM   #2 (permalink)
TOM
Guest
Posts: n/a
View TOM's Photo Gallery
Re: For those whose A/C only works on hi
Randy wrote:
[color=blue]
> and a phillips. ;) Hope this helps someone.[/color]
That's good advice. Others have posted similar instructions in the past,
but I think this is the kind of thing that should be posted on a
semi-regular basis since I seems to be a fairly common problem. I am now
down to (up to?) the top two speeds in my '88 pickup. I had the top
three, but the lower speed, #2 on the switch died last winter. The
higher the resistance, the slower the blower motor runs, but the hotter
the resistor gets. I assume that at its highest setting there is no
resistance present...
Tom - Vista, CA
Old 07-08-2006, 03:28 PM   #3 (permalink)
Randy
Guest
Posts: n/a
TOM <tomjc@catz.org> wrote:
[small snip]
[color=blue]
> I am now
>resistance present...[/color]
Makes sense.
When I bought this truck in 2002 the A/C did not work on low, but worked
on setting 2, 3 and 4. Like you, the lower settings began to cease
working until only hi worked. If I had known all I needed to do was take
30 seconds to replace this part I would have done it in 2002! How nice
to be able to take it to the gas station this morning with the A/C on
low! The fan makes virtually no noise on low and keeps the truck very
chilly.
I still have the original A/C system in this, meaning if anything ever
goes wrong I have to upgrade it to the new type of A/C rather than
repair or service it. Do you still have the original A/C in your '88?
IAC it blows cold as a freezer, so no problem there. I know some people
adjust the temp slider to mix some heat with the A/C when it blows too
cold. Does this slider adjust down the amount of freon being used, or
merely introduce hot air along with the cold? That's probably a stupid
question, but... ;)
TIA
Old 07-08-2006, 04:41 PM   #4 (permalink)
TOM
Guest
Posts: n/a
Randy wrote:
[color=blue]
> [small snip]
>[color=green]
>>I am now
> Makes sense.
> chilly.
> question, but... ;)
> TIA[/color]
Unfortunately, I only have the heater. My truck was ordered as part of a
fleet of service trucks. Before the trucks were off-loaded in Long Beach
(or where ever it was they arrived), the ordering company filed for
bankruptcy. The trucks were sold through local dealers. The dealer I
bought mine from in Escondido (Southern California) had three or four
sitting on the lot, all dark gray, with no options. They had vinyl bench
seats, standard cabs, vinyl floor mats (no carpet), 4-speed
transmissions, no A/C, no power steering, and no radios. They were
really base models. The engines were 22Rs with carbs, not fuel injection.
My brother referees to it as a Toyota GTU (Generic Transportation Unit).
How right he is... :>))
I've had it for over 18 years and it has about 186,000 miles on it. A
couple of head gaskets, a crank pulley sleeve, a fuel pump, a brake and
clutch master cylinder, and the usual stuff, filters, brakes, etc. I've
been very happy with it.
Tom - Vista, CA
Old 07-08-2006, 06:55 PM   #5 (permalink)
Sir F. A. Rien
Guest
Posts: n/a
View Sir F. A. Rien's Photo Gallery
On Sat, 08 Jul 2006 12:28:41 -0700, [email]nospam@hm.pls[/email] (Randy) found these unused
words floating about:
[color=blue]
>[small snip]
>[color=green]
>> I am now
>Makes sense.
>chilly.
>question, but... ;)
>[/color]
It doesn't "use" freon ... the refrigerant is in a closed system (or should
be!).
Two methods of regulation - add warmth via the heater or cycle on/off the
compressor as do homes.
Old 07-09-2006, 02:01 AM   #6 (permalink)
Randy
Guest
Posts: n/a
[color=blue]
>fleet of service trucks. [...] They were
>really base models. The engines were 22Rs with carbs, not fuel injection.[/color]
Sounds like it's done good by you. :)
[color=blue]
>How right he is... :>))[/color]
LOL. Sounds like something Seven of Nine woulda said (from Star Trek
Voyager).
[color=blue]
>been very happy with it.[/color]
Lucky for the truck it found a good home right off the bat. ;)
Old 07-09-2006, 02:03 AM   #7 (permalink)
Randy
Guest
Posts: n/a
Sir F. A. Rien <jaSPAMc@gbr.online.com> wrote:
[color=blue]
>be!).[/color]
But eventually people need to add refrigerant because ... ? It just
breaks down over time chemically?
Old 07-09-2006, 12:50 PM   #8 (permalink)
Sir F. A. Rien
Guest
Posts: n/a
On Sat, 08 Jul 2006 23:03:39 -0700, [email]nospam@hm.pls[/email] (Randy) found these unused
[color=blue]
>[color=green]
>>be!).[/color]
>breaks down over time chemically?[/color]
Usually minute cracks that you can't 100% seal. That's why they make a
'sealant' version for older vehicles. The heat/cold swings as well as
vibration make it inpossible to maintain a perfect seal.
I've an Amana roof A/C unit that's 20+ years old, never been touched and is
still meeting every performance check. How often do you add freon to
refrigerators? They're about the same as a car's system in size.
By "USE" I meant as in consume, the OP commented that altering the
temperature might "use less freon'.
Old 07-09-2006, 01:21 PM   #9 (permalink)
TOM
Guest
Posts: n/a
Sir F. A. Rien wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>>>be!).[/color]
> temperature might "use less freon'.[/color]
Good points. Perhaps if we took our refrigerators and/or household
cooling systems out 4-wheeling, they you would develop leaks after a few
years... :>))
Tom - Vista, CA
Old 07-09-2006, 05:44 PM   #10 (permalink)
Randy
Guest
Posts: n/a
[color=blue]
>[color=green]
>>[color=darkred]
>>>be!).[/color]
>refrigerators? They're about the same as a car's system in size.[/color]
Great point.
[color=blue]
Thanks for the explanation. I won't feel like I'm using up the
refrigerant now when I run the A/C. :) I don't want to be forced to
replace this A/C b/c it works so good (and of course the expense). But I
was thinking the more I use it the sooner the freon (or whatever they
use in these old ones) will be gone. But if it is only dependent on
leaks then it makes no never mind! :)
Old 07-10-2006, 12:08 PM   #11 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
"Randy" <nospam@hm.pls> wrote in message
news:7arta25k1dtk0c24v2s88di345vpe63mh0@4ax.com...[color=blue]
> motor. Turns out all I needed was a new blower resistor.[/color]
This is common knowledge. When the fan speeds are no longer adjustable, the
resistor pack is the culprit. When the fan will not come on at all, then the
resistor pack might be the culprit, OR the motor could be burnt out.
BB code is Off
Smilies are Off
[IMG] code is Off
A/C Light Flashes - AC Doesnt work jrock80 Camry & Solara Lounge 24 06-19-2006 12:48 PM
A/C only works one hour dodo0132 Camry & Solara Lounge 11 09-06-2004 11:27 PM
A/C constantly on - 96 Tercel Esox Tercel, Paseo, Starlet, and Sera Forum 1 08-09-2004 10:20 AM
'89 4 cyl camry.. O/D lights blink off and on as well as A/C Bobby C 01TA 1st & 2nd Generation (1983–1986 & 1987-1991) 1 06-09-2004 04:21 PM
