Power antenna replacement on 99 Tacoma, Help please.. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-11-2006, 12:01 PM   #1 (permalink)
Scott
Guest
Posts: n/a
View Scott's Photo Gallery
Hi everyone,
I have a 99 Tacoma Limited which means it came with a power antenna from the
factory. Well it finally gave out so I ordered one off of Ebay trying to
avoid the 140.00 the dealer wanted. My question is it has 3 wires a ground
and then 2 that connect to the radio. The manual shows a relay for the
antenna that came stock located near the radio. Will I need to connect this
antenna before the relay or after?
Thanks,
Scott..
Old 07-12-2006, 02:52 AM   #2 (permalink)
Joseph Wind
Guest
Posts: n/a
View Joseph Wind's Photo Gallery
Re: Power antenna replacement on 99 Tacoma, Help please..
I have a 93 and my antenna motor is still going strong. I did have to
replace the mast 8 years ago. It was quite easy, but very messy. What brand
antenna did you buy? Harrada is the OEM for Toyota, I believe.
"Scott" <nope@haha.com> wrote in message news:eYPsg.19$cv.13@fe05.lga...[color=blue]
> Hi everyone,
> the factory. Well it finally gave out so I ordered one off of Ebay trying
> to avoid the 140.00 the dealer wanted. My question is it has 3 wires a
> ground and then 2 that connect to the radio. The manual shows a relay for
> the antenna that came stock located near the radio. Will I need to connect
> this antenna before the relay or after?
> Thanks,
> Scott..
>[/color]
Old 07-13-2006, 10:41 AM   #3 (permalink)
crashq
Guest
Posts: n/a
View crashq's Photo Gallery
I can't say for sure, but would guess after. Just hook it up like the
factory antenna. Did your moto go completely belly up? There isn't much
to them, so that would be strange. Take it apart when you get it out of
the truck and check it out.
I have a 1992. When I had to replace the mast, which require
disassembly of the motor housing, It required pulling the dashboard out
because the cable was wrapped around the frame support (a round bar)
behind the dash. It simply plugged into the radio and relay behind the
radio.
BB code is Off
Smilies are Off
[IMG] code is Off
Power antenna replacement newbie212 T-100 1 03-16-2010 07:38 PM
Power steering replacement. 1987camry Camry & Solara Lounge 0 08-10-2002 05:08 PM
Power Antenna Shot - What to do? Killinchy Camry & Solara Lounge 17 04-18-2002 08:42 PM
