Re: 96 RAV4 Ignition Coil Testing
Are you getting 0.05 or 00.5 (which is properly expressed as 0.5, by the
way)? 0.05 is way below the spec you posted, 0.5 is right in there where
you want it.
If you have multiple coils, have you tried swapping them around to see if
the dead cylinder follows the coil?
"shavros" <marius_bingue@yahoo.com> wrote in message
news:1153034328.078189.276120@m79g2000cwm.googlegroups.com...[color=blue]
> I'm getting a 00.5 ohm reading on the primary coil. Ohmmeter is set on
> 200 ohm. The specs are Cold: 0.36 - 0.55 Ohm Hot: 0.45 - 0.65 Ohm. Do
> i need to replace coil?
>[/color]
