Tire trouble! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-16-2006, 01:24 PM   #1 (permalink)
Paul
Guest
Posts: n/a
View Paul's Photo Gallery
Tire trouble!
Hello,
I have a 2003 Toyota Tundra... Tires have worn out in 11k miles! Didn't know
why until Toyota sent me a recall for bad ball joints! So all the time I was
driving, the front end alignment was very bad.. It was due to the bad ball
joints..
Called the complaint line for Toyota after I had the ball joints replaced
and the front end aligned and asked if they could help me out with the tire
replacement.. It was a flat out "NO"..
So no more Toyota vehicles for me! Case closed!
PC
Old 07-16-2006, 03:59 PM   #2 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Re: Tire trouble!
Dude, the ball joint recall has nothing to do with freeplay that could
cause premature tire wear. As ray responded to your cross post in
alt.toyota, the alignment is done because of the recall (removing ball
joints requires re-setting the alignment), not because the original ball
joints may have been scratched during assembly. But feel free to buy a
dodge that really DOES have loose ball joints before 30k miles.
Old 07-16-2006, 07:22 PM   #3 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: Tire trouble!
If you're lucky maybe you can still get a Ford Exploder with Firestone
tires?
"Paul" <britania@All2Easy.net> wrote in message
news:44ba76e7$0$3627$822641b3@news.adtechcomputers.com...[color=blue]
> Hello,
> know why until Toyota sent me a recall for bad ball joints! So all the
> time I was driving, the front end alignment was very bad.. It was due to
> the bad ball joints..
> tire replacement.. It was a flat out "NO"..
> PC
>[/color]
Old 07-16-2006, 07:39 PM   #4 (permalink)
S.Lewis
Guest
Posts: n/a
View S.Lewis's Photo Gallery
Re: Tire trouble!
> Hello,
> PC
>[/color]
What brand/model tire out of curiousity? Have you attempted to contact an
affiliated dealer to see if there may be any coverage for the tire there?
Old 07-16-2006, 11:55 PM   #5 (permalink)
Skip
Guest
Posts: n/a
View Skip's Photo Gallery
Re: Tire trouble!
On Sun, 16 Jul 2006 13:24:27 -0400, "Paul" <britania@All2Easy.net>
wrote:
[color=blue]
>Hello,
>joints..
>PC
>[/color]
It's been my experience that tires on new cars are warranteed by the
tire's manufacture, not the auto dealer. Call who ever made the tires
and enquire.
Skip
Old 07-17-2006, 09:25 AM   #6 (permalink)
donnoble@gmail.com
Guest
Posts: n/a
View donnoble@gmail.com's Photo Gallery
Re: Tire trouble!
Certainly, that is your decision. However, where is the logic of
dropping a dependable vehicle like Toyota, for other makes that are
plagued with mechanical problems? You will spend more in the long run
for repairs than the cost of those $400 tires.
Paul wrote:[color=blue]
> Hello,
> joints..
> PC[/color]
Old 07-17-2006, 02:05 PM   #7 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: Tire trouble!
> Hello,
> PC[/color]
I don't think the ball joints in the recall will affect tire wear as badly
as you describe. Since you have not actually described what the tire wear
is, I would like to suggest that there are many things that you can do to
affect tire wear even more than ball joints.
Old 07-17-2006, 02:12 PM   #8 (permalink)
Jeff Strickland
Guest
Posts: n/a
Re: Tire trouble!
Actually, if one actually looks at what is done to replace the ball joints,
it is clear that the recall can easily be done without affecting the
alignment at all. I was surprised to see this, but it's fact. They only
CHECK the alignment, and adjust if needed but odds favor it not being
needed.
My daughter had a used Tacoma PreRunner that had been ofroaded (we think)
and the lower control arm on one side was a bit tweaked -- it had some deep
scratches where the truck had be driven over large rocks, I suspect the deep
scratches resulted from being drug, but I digress. Her truck had the recall
done, and the front end was the same afterwards, so it must have been
straight even before the ball joints were done. The service department noted
that the alignment was inspected/checked, but there was no note that it had
been changed. A quick inspection of the parts involved shows that the ball
joints can be replaced without altering the alignment settings. An alignment
after the ball joints is more of a CYA approach to the repairs than a
requirement of the repairs.
"qslim" <Suckers@suckersdotcom> wrote in message
news:7c6f443121ac09a2311c4bc25b66d89d@localhost.talkaboutautos.com...[color=blue]
>[/color]
Old 07-17-2006, 02:28 PM   #9 (permalink)
Ken Shelton
Guest
Posts: n/a
View Ken Shelton's Photo Gallery
Re: Tire trouble!
> Hello,
> joints..
> PC
>[/color]
1) OEM tires are usually not warranted for mileage.
2) Why didn't you look at the tread on your tires and notice rapid
wear far before they were worn out?
3) Were the tires correctly inflated all the time?
4) If the alignment was so bad that the tires work in 11k, there
usually is something so wrong that the driving feel is off. Did the
truck pull left or right?
5) Buy another brand at your peril. There is no perfect brand.
Every other brand I know of has many more problems.
Ken
Old 07-17-2006, 05:27 PM   #10 (permalink)
qslim
Guest
Posts: n/a
Re: Tire trouble!
SSSHHHHHHHH! You'll spoil it for everyone!
You're absolutely right, Jeff. Toyota put the alignment in the recall
to cover their ass. I haven't seen one yet that needed re-aligning. The
ball joints and studs are tapered, so they self-center when being
installed.
Old 07-18-2006, 11:10 AM   #11 (permalink)
Jeff Strickland
Guest
Posts: n/a
Re: Tire trouble!
Not to mention they recall the lower ball joint, but the load bearing ball
joint is the top one.
news:cc73d70e769fc7217731557a172a6303@localhost.talkaboutautos.com...[color=blue]
> installed.
>[/color]
Old 07-21-2006, 06:22 PM   #12 (permalink)
Its Just Me
Guest
Posts: n/a
View Its Just Me's Photo Gallery
Re: Tire trouble!
There you go Hot Rod. Think Toyota screwed you buy a Ford or a
Chevy.......Then we'll discuss SCREWED......
BB code is Off
Smilies are Off
[IMG] code is Off
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 02:17 PM
Tires Feedback: Everyone please contribute. EKam Hardcore Tech and Competition 98 12-19-2006 03:05 AM
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 11:53 PM
Pro Comp Tire Seperation Causes Crash Z71sc Feedback: Buyers, Sellers, and Vendors 0 10-19-2004 06:01 PM
