Rear Brake Job turns into axle replacement???? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-17-2006, 01:33 AM   #1 (permalink)
AirWolfe1
Guest
Posts: n/a
View AirWolfe1's Photo Gallery
I apologise in advance if this post is inappropriate to this forum, but
through my search of forums, you folks seem to know your sh_t better
than any others.
My son bought a 96 tacoma 2.7L 4x4 5-speed manual with 238,000 mi. It
seems to run and shift good, but as we tackled the rear brakes to fix
the e-brake all sh_t broke loose. Drums were really really rusted and
even after turning back the star tension adjuster to loosen the pads it
would not budge. Did the 2 screws in the drum trick...cracked the
drum....still frozen. Beat....heat...beat....heat.....nothin. Noticed
the e-brake bell crank on the back side was boot was missing and
completely rusted and would not budge (both sides). Bolts are all
rusted so you can't get a wrench on anything. It is the same on both
sides. The threads on the right side drum to do the 2 screw trick we
found to be stripped. My guess is it has been a long long time since
any work has been done to these rear brakes. I'm at the point where I
think I need to just pull the axles and replace with a complete
servicable assembly. I finally got the drum on the left side off, and
everything inside is a mess and completely rusted.
I would appreciate the forum's advice and any approximate estimates for
parts.
Sorry for the long post...thanks for the response in advance.
Old 07-30-2006, 05:30 PM   #2 (permalink)
jbclem
Guest
Posts: n/a
View jbclem's Photo Gallery
Re: Rear Brake Job turns into axle replacement????
For the right side drum have you thought abouit drilling and tapping the threaded holes
to the next size. It sounds like the car had been sitting in a pool of water and then
not driven for a long time.
jc
"AirWolfe1" <airwolfe1@gmail.com> wrote in message
news:1153114416.472547.61330@i42g2000cwa.googlegroups.com...[color=blue]
> than any others.
> parts.
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Rear Brake Noise sandman 1st Generation (1998-2003) 14 10-04-2007 12:23 AM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 06:51 AM
just done my rear disc brake conversion now starts the problems gasman Archived Corolla threads 30 06-02-2006 02:39 AM
Rear Brake Valve Replacement spageroni 89-95 Toyota Pickup/Hilux 5 03-02-2006 02:31 PM
rear axle questions RadioFlyer90 89-95 Toyota Pickup/Hilux 9 01-25-2006 06:13 PM
