AC Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-18-2006, 01:08 PM   #1 (permalink)
RedForeman
Guest
Posts: n/a
View RedForeman's Photo Gallery
AC Issues
My truck is a 98 Taco SR5 V6 5VZ-FE, the AC Compressor goes out. I
replace the compressor and research what oil to put in(PAG), how much
1.9oz, and then had PepBoys recharge it. During the recharge, the
technician tells me that when he hooked up to the low side, it showed
85psi, and that was too high, he's not touching it... I convinced him
and he continued. When done, the AC blows cold for 5 minutes, then
gets hot. I put a pressure guage on it, and it's showing 75psi for me,
which is too high. Now, after a couple of days, when the motor is cold
in the morning, it blows cold for 15m, then gets hot. In the middle of
the day when motor is hot, no coldness at all...
My questions are:
How many oz of PAG SHOULD the system have?
How did he "over charge" when he's got a better guage then me?
Is there an easier way of evacuating a system than having a machine
doing it?
Am I right in assuming, it's got too much oil, not enough refrigerant,
and too much pressure?
BTW, the expansion valve was changed as well and is NOT clogged, for
the record.
Thanks, just curious....
RedForeman
with 176,356 miles and going strong.
Old 08-04-2006, 04:44 PM   #2 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
Re: AC Issues
"RedForeman" <RedForeman@gmail.com> wrote in message news:1153242531.046683.99960@35g2000cwc.googlegroups.com...[color=blue]
> My questions are:
> How many oz of PAG SHOULD the system have?[/color]
In the compressor, condenser, reciver, or whole system?
[color=blue]
> How did he "over charge" when he's got a better guage then me?[/color]
The gauge pressure # in a system that is not running will be the same
either way and relates to tempature, not the charge.
[color=blue]
> doing it?[/color]
NO.
[color=blue]
> and too much pressure?[/color]
No.
[color=blue]
> the record.[/color]
What about the reciever/dryer? It was replaced right? Some of the oil is in there too.
Was the condenser flushed? (bad compressor right) Some oil is in there too.
The sight glass should be liquid on a running system. Bubbles indicate a low charge.
The sight glass should bubble and foam when the compressor cycles off. If it remains
liquid its over charged.
It sounds like a wet system to me. Maybe contaminated oil from the old compressor.
[color=blue]
> RedForeman
>[/color]
GL
Dan
BB code is Off
Smilies are Off
[IMG] code is Off
AC performance humidity dependent, need help ruoknow Camry & Solara Lounge 8 04-28-2006 04:53 PM
'95 AC Question Jevid Archived Corolla threads 0 08-30-2005 11:30 AM
New User from the Sooner Nation! 87 Camry Wagon AC issues .... Lin Introduce Yourself Here 0 07-13-2005 01:56 PM
'02 Tacoma AC Question shane28462 1st Generation (1995.5–2004) 0 07-10-2005 02:48 AM
MK3 TURBO!, No Heater, No AC, IM STUMPED!!! seiffert Supra Forum 0 04-24-2004 02:36 PM
