Re: AC Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-19-2006, 09:17 AM   #1 (permalink)
Ken Shelton
Guest
Posts: n/a
View Ken Shelton's Photo Gallery
Re: AC Issues
RedForeman wrote:[color=blue]
> My truck is a 98 Taco SR5 V6 5VZ-FE, the AC Compressor goes out. I
> replace the compressor and research what oil to put in(PAG), how much
> 1.9oz, and then had PepBoys recharge it. During the recharge, the
> technician tells me that when he hooked up to the low side, it showed
> 85psi, and that was too high, he's not touching it... I convinced him
> and he continued. When done, the AC blows cold for 5 minutes, then
> gets hot. I put a pressure guage on it, and it's showing 75psi for me,
> which is too high. Now, after a couple of days, when the motor is cold
> in the morning, it blows cold for 15m, then gets hot. In the middle of
> the day when motor is hot, no coldness at all...
> My questions are:
> How many oz of PAG SHOULD the system have?
> How did he "over charge" when he's got a better guage then me?
> Is there an easier way of evacuating a system than having a machine
> doing it?
> Am I right in assuming, it's got too much oil, not enough refrigerant,
> and too much pressure?
> BTW, the expansion valve was changed as well and is NOT clogged, for
> the record.
> Thanks, just curious....
> RedForeman
> with 176,356 miles and going strong.
>[/color]
Was the air that entered the system when you changed the compressor
evacuated before you charged? A deep vacuum needs to be pulled on
the system before recharge. You could try just letting the air &
refrigerant blow out of a high spot on the system and recharge the
refrigerant just until the compressor no longer short cycles. Of
course, the right way is to fully evacuate the system and recharge
the correct weight of refrigerant.
Ken
BB code is Off
Smilies are Off
[IMG] code is Off
How cold does AC really get? thapranksta Camry & Solara Lounge 24 05-04-2006 07:00 AM
'95 AC Question Jevid Archived Corolla threads 0 08-30-2005 11:30 AM
New User from the Sooner Nation! 87 Camry Wagon AC issues .... Lin Introduce Yourself Here 0 07-13-2005 01:56 PM
'02 Tacoma AC Question shane28462 1st Generation (1995.5–2004) 0 07-10-2005 02:48 AM
'00 4Runner AC issue nspringer 4Runner Lounge 1 07-29-2004 02:24 PM
