'94 4Runner air conditioning update
Turns out just as some suspected it was the magnetic clutch coil that
was shorting. Got another coil and guess what. If I used the outer
snap ring shipped with the new parts the same thing would happen again.
This snap ring for the shaft was typical, with the wider portion being
in the middle and tapering toward each end WHICH WILL NOT BEAR AGAINST
THE BEARING PROPERLY. This allows the bearing to move back and forth
and this is what destroyed the coil.
Toyota will sell you the correct WAVEY snap ring (check the
orientation) for about $2.15. This may save someone a big headache.
I wonder how many people have installed this incorrect snap ring and
how many are out there with same?
Good luck all.
dennis
in nca
