Re: loosing coolant in toyota 4runner
If you are sure there is none leaking, then it might be your head
gasket. Take the oil filler cap off and see if there is any whiteish
sludge on it. Check the dipstick too. If there is anything on either
of those that is definitely not oil, then coolant is somehow getting
into your oil, most likely through a bad head gasket.
If the engine oil looks clear and sludge free, check around the engine
to see if its leaking anywhere, maybe when it's running. I'm sure they
already did that at the dealer, but???
[email]malavspandya@gmail.com[/email] wrote:[color=blue]
> i have a 4runner 01, < 60K miles. I had over heating problem and i was
> forced to change radiator, hoses . after a month, it over heated again.
> they put the coolant again (since it was not there), after a month it
> happend again and they again put the coolant again. Then i went to the
> dealer, and those guys changed "engine core plugs". after 15 days i
> noticed again and coolant was not there in the RESERVE, so i went back
> to them and they again changed "engine core plugs". This time they told
> me if this happens again , they will have to change the whole engine.
> Somebody please help me out, i know nothing about automobiles other
> then driving.Where is collant going? Dont know whom to believe other
> then blog friends. Give your thoughts as much as you can. Thanks in
> advance.[/color]
