dark dashboard instrument panel - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 09-23-2006, 12:26 AM   #1 (permalink)
planetcalculi
Guest
Posts: n/a
View planetcalculi's Photo Gallery
I have a 2001 Toyota Tundra. About two days ago, I noticed that the
speedometer and other gauges will not light up. All of the other lights
on the truck, including the dome lights, bed light, running lights,
etc. work. I checked the fuses but none of them are burnt. Furthermore,
when the headlights are turned off, the radio is lit up. When the
headlights are turned on, the radio is not lit, but it still works. I
just recently had two keyless remotes reprogramed. Is it possible that
the service technician did something to the instrument panel wires? I
intend to take the truck to the dealer but I thought I would first ask
if anybody had expreienced the same problem and had a easy solution.
Thanks.
Old 09-23-2006, 04:36 AM   #2 (permalink)
: P
Guest
Posts: n/a
View : P's Photo Gallery
Re: dark dashboard instrument panel
have you checked the dimmer control switch. it may have be accidentally
adjusted. I don't know exactly where it would be for your truck, so you
should consult your owners manual for the location. look for the
instrument/dash disgram and it should be noted.
"planetcalculi" <one4all@pacbell.net> wrote in message
news:1158985578.560253.175160@k70g2000cwa.googlegroups.com...[color=blue]
> Thanks.
>[/color]
Old 09-24-2006, 01:00 AM   #3 (permalink)
planetcalculi
Guest
Posts: n/a
Thanks for the suggestion, but that is not the problem.
: P wrote:[color=blue]
> news:1158985578.560253.175160@k70g2000cwa.googlegroups.com...[color=green]
> > Thanks.
> >[/color][/color]
Old 09-24-2006, 06:11 AM   #4 (permalink)
ff
Guest
Posts: n/a
View ff's Photo Gallery
> Thanks.
>[/color]
The radio has two light levels. It's bright when the headlights are off so
you can see it during the day and it is dimmed when the headlights are
on at night. So it's not getting the power for dimmed lighting that is
also goes to the instrument lights.
There's probably a loose or broken wire. Might have happened when
it was serviced.
BB code is Off
Smilies are Off
[IMG] code is Off
Door Panel Removal Tutorial (56k, only if absolutely necessary) Delay_FTB Camry & Solara Lounge 17 12-18-2011 11:37 PM
GPS Antenna Location on Gen 6 hybridamp 5th & 6th Generation (2002-2006 & 2007-2011) 2 08-30-2006 01:13 PM
location of instrument panel fusebox? prcummings 1st Generation (1998-2003) 1 07-06-2006 08:40 PM
Instrument Panel Lights Not Workin goderaj 4Runner Lounge 0 01-26-2006 11:28 PM
Illumination lights for the instrument panel don't work after stereo installation qwertvt Audio, Video, and Security - Tech 0 01-21-2006 11:57 PM
