Brake shims - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 09-23-2006, 03:43 PM   #1 (permalink)
Nick
Guest
Posts: n/a
View Nick's Photo Gallery
Brake shims
I have a 90 2wd pickup. All the brake pad shims are missing.
I got a set of shims from Toyota, but there are two shims per pad and I'm
not sure how to install them.
There is a solid silver shim and a black shim with slots cut in it. I
looked at a Chilton manual and the diagram showed the black shim next to the
pad and the silver shim over it.
The only way I can make that fit, is if the two tabs on the black shim point
away from the pad.
Is this correct?
Thanks
Nick
BB code is Off
Smilies are Off
[IMG] code is Off
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 02:32 AM
MR2 Brake Shims numbone MR2 Forum 1 06-23-2005 12:42 AM
rav4 brake bleeding rav4jeff RAV4 Forum 1 12-26-2004 09:02 PM
