oill change light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 10-03-2006, 10:52 AM   #1 (permalink)
DM
Guest
Posts: n/a
View DM's Photo Gallery
oill change light
Hi,
Sorry if this has been asked before. I have a '06 Tacoma 4 cyl 5 speed. How
do I reset the oil change due light after changing the oil and filter?
Thanks in Advance,
Dwight
Old 10-03-2006, 11:44 AM   #2 (permalink)
R.E.Pasco
Guest
Posts: n/a
View R.E.Pasco's Photo Gallery
Re: oill change light
Owners manual has a section on resetting the warning. Basically, depressing
and holding in the the odometer change button while your turned on the
ignition. I think I had to depress the shaft several times to clear the
digit positions at that point. Best to check that owner's manual.
b"DM" <poptime-nospam@comcast.net> wrote in message
news:7dqdnV0p8N3Z5L_YnZ2dnUVZ_o2dnZ2d@comcast.com...[color=blue]
> Hi,
> How do I reset the oil change due light after changing the oil and filter?
> Thanks in Advance,
> Dwight
>[/color]
Old 10-03-2006, 11:48 AM   #3 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
> Hi,
> Thanks in Advance,
> Dwight[/color]
With the ignition off, press and hold the trip meter, then start the truck.
Continue to hold the trip meter for five seconds once the truck starts.
Mike Harris
Austin TX
Old 10-04-2006, 01:19 AM   #4 (permalink)
DM
Guest
Posts: n/a
Mike and R.E., thanks. I will try that and I'll try to do a better job of
reading the manual. :)
Dwight
Old 10-04-2006, 01:42 PM   #5 (permalink)
R.E.Pasco
Guest
Posts: n/a
Went back and looked at the manual. It says to put it on the odometer, vice
trip meters, before you turn off the ignition. Depress and hold the
button/shaft, turn on the ignition and hold for at least 5 seconds to clear.
> Hi,
> Thanks in Advance,
> Dwight
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Map Lights Come ON with Dome Light (New Method) Pb 2nd Generation (2005+) 239 10-23-2011 11:28 PM
reset procedure Service Maintenance Reminder Light Suikelley 2nd Generation (2004-2010) 1 08-18-2007 12:24 PM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 09:23 PM
how do you change the signal light? flyingchicken 1st Generation (1995-1999) 2 07-30-2006 03:24 PM
how do you change rear break light plastic nofear4189 Camry & Solara Lounge 6 12-29-2004 07:43 PM
