Re: remote start on 2004 Sequoia, good idea? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 10-04-2006, 11:50 PM   #1 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Wed, 4 Oct 2006 21:22:39 -0400, "harry" <harry_liuNOSPAM@lcc.com>
wrote:
[color=blue]
>As title.
>It is getting cold, a remote start would be a convenient feature for me in
>the morning.
>Any known issue? Any successful story? Cost?[/color]
For openers, auto starters are not that good for the car engine. If
you leave it idling more than roughly 30 seconds before driving it
off, you risk the unburned fuel getting past the piston rings and
diluting the oil.
It only takes about 15 to 30 seconds to get the oil circulating
everywhere in the engine, including the hinterlands at the back of the
camshaft. A bit more if it's way below zero outside and you are using
regular oil, a lot less on full synthetic oil. As soon as you pass
the 30-second point, it's actually better on the car to drive away
gently and take it easy for the first few blocks - this allows the
transmission, axles, etc to also warm up slowly.
If you really want the engine to be pre-warmed up and getting the
car toasty the minute you get in and start the engine, install a block
heater and have the timer set for a few hours ahead of your normal
departure time in above-freezing weather, and all night if it's way
cold outside. Below 30F would be my threshold, YMMV.
And if it's a stick-shift, fuhgeddaboudit. There's now way to make
sure it's in neutral and /stays/ in neutral, and you could find the
car a few miles away...
That said, Auto Start is best installed integrated with a burglar
alarm - That's how I did it several moons ago, though I rarely use it,
it was more of a "can I do it?" exercise. A simple auto-start would
leave the car running without the keys in the ignition, and all a
crook would have to do is get inside (slim-jim or break a window with
a big Channellock or pipe wrench), break the steering wheel lock (same
big wrench on the cylinder) and drive away.
With the auto-start integrated in the alarm system, the engine dies
if the alarm is tripped. The auto-start button doesn't disarm the
alarm, you have to hit the disarm button immediately before entering
the car, and you have a time limit to put the key in the ignition and
turn it to "Run".
And it's looking for the proper entrance sequence, including
watching the 'key in ignition lock' sense line to see if the cylinder
is being forced instead of a key being used like normal.
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
Remote Start on Manual Transmission cars es250nut Audio, Video, and Security - Tech 2 09-13-2004 12:10 AM
Installed Remote Start in a 1996 camry, now transmission mal critikal 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-03-2002 10:29 AM
