Re: Ignition key issue
"Phisherman" <noone@nobody.com> wrote in message
news:980ji21sg86a011pm7lv07aogapl3vqhgv@4ax.com...[color=blue]
> On Sun, 8 Oct 2006 18:39:48 -0400, "Tom in Macon"
> <TomMacon@member.org> wrote:
>[color=green]
>>news:nimii2hrp9v7aqckoup3pkea40lp7allbi@4ax.com...[color=darkred]
>>>I have a 2006 Tundra. One time my key would not turn in the ignition.
>>> I tried exiting the vehicle, used my keyless entry, and tried again.
>>> The key would not turn. I tried backing off the key a hair, still no
>>> turn. After about 10-15 attempts, the key worked. Now I am paranoid
>>> this will happen again.[/color]
>>Have you tried turning your steering wheel slightly while turning the key?
>>[/color]
> Possibly. At the time I was not sure what I did or what happened that
> the key finally worked. I may have moved the steering wheel
> unintentionally, and did not realize this could cause an ignition key
> not to work. (Is this a common occurrence with new vehicles?) I've
> been driving for over 35 years and this is first for me. Thanks.[/color]
It's not common, but it happens. If you shut the ignition off, and move the
steering wheel, it will lock the ignition switch. You can usually hear it
click as it locks. Most drivers don't move the steering wheel after they
shut the car off, so the ignition never locks. These ignition locks have
been in cars and trucks for years.
