Re: Transmission Fluid 2006 Tundra 4.7 V8 Double Cab 4x4
[email]test@test.com[/email] wrote:[color=blue]
> How do you check transmission fluid levels and add fluid if
> necessary for a 4.7 liter V8? For the life of me, I can't find a dip
> stick leading to the transmission and the owner's manual doesn't address
> it. There is a small plug next to the drain plug on the transmission pan
> that says "check" on it but I'm afraid if turn it out, I'll have
> transmission fluid flowing onto the floor.
> If one needed to add transmission fluid, where do you introduce it?
> Unlike my old Chevrolet 305 engine, I simply can't see where the spout
> and dipstick are for the automatic transmission.
> This a new truck for me and I'm just trying to learn where
> everything is. Thanks in advance.[/color]
Look under the truck where you park it. If you don't see a red
puddle, nor the underside of the truck is wet with a light red oil,
the fluid is likely still in the transmission.
The transmission isn't really sealed. It has a fill plug much like
your differential or a manual transmission. Fill to that level. It
also has a vent so expansion from warmth doesn't blow the seals out,
nor contraction in the cold suck the seals in.
Ken
