T100, V6 Starter problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 10-11-2006, 01:07 PM   #1 (permalink)
BOB
Guest
Posts: n/a
View BOB's Photo Gallery
!996, T100, V6 automatic. Starter sparatic ( like 2 out of 10 tries) drags
or just clicks but most times, after several tries it will start.
I had battery replaced and this cured problem for a while but then some
problem, took it to mechanic who tested started and could not
find anything wrong. Next it would not turn over at all until I put it on
the charger for a couple of hours now starts but old problem, drags
clicks etc. Sure I am going to get caught out in the boondocks some night
with a long walk. Does anyone have any thoughts?
Bob
Old 10-11-2006, 06:49 PM   #2 (permalink)
rb
Guest
Posts: n/a
View rb's Photo Gallery
Re: T100, V6 Starter problem?
"BOB" <twomay@sbcglobal.net> wrote in message
news:Cx9Xg.13938$6S3.7413@newssvr25.news.prodigy.net...[color=blue]
>[/color]
How's the connection at the starter look?
Old 10-11-2006, 10:11 PM   #3 (permalink)
Jarhead
Guest
Posts: n/a
View Jarhead's Photo Gallery
"rb" <123@Ishotmr.lee> wrote in message
news:hyeXg.13381$cc3.10501@tornado.rdc-kc.rr.com...
drags
some
it on
night
Or, the connection at the battery. My son had the same problem with his
Jeep and we noticed corrosion where the positive wires went into the
connector. We cut off the wires, cleaned them after taking off some
insulation, and then went to WallyWorld and bought and installed a
connector. He hasn't had any problems since.
Jarhead
Old 10-12-2006, 12:48 AM   #4 (permalink)
Paul.
Guest
Posts: n/a
View Paul.'s Photo Gallery
Sounds like the starter contacts are going. There are a lot of sites that
describe the repair including:
[url]http://yotarepair.com/startercontacts.html[/url]
[url]http://www.4x4wire.com/toyota/maintenance/starter/[/url]
[url]http://www.4crawler.com/4x4/CheapTricks/Starter.shtml[/url]
Put a voltmeter in the lighter and watch the battery volts when it doesn't
start. If the starter clicks and the voltage doesn't go way down (less than
12 volts), then the starter isn't making electrical contact. The battery
voltage when the truck is not running should be between 12 and 13 volts.
When the starter pulls a lot of amps the voltage will drop and when the
truck is running the alternator should try to maintain the battery voltage
at 13 to 14 volts to charge the battery.
Before you remove the starter, clean ALL the battery cable connections
including the ground cable where it attaches to the battery and where it
attaches to the engine. Rust buildup will also keep the starter from fully
engaging.
Keep the group informed on what you find and good luck!!
Paul.
> 1996, T100, V6 automatic. Starter sparatic ( like 2 out of 10 tries) drags
> Bob
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
1996 T100 starting problem Solidworkingman T-100 17 10-25-2008 03:39 PM
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 07:20 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 12:14 PM
starter problem? tercel_man Tercel, Paseo, Starlet, and Sera Forum 9 01-08-2006 08:01 PM
