Re: STEREO QUESTION
Alrighty then,
First you have to remove the drivers and passengers lower dash panels..
This should be about 4 - 5 phillips screws and 2 11mm bolts. Second removed
the lower center panel by removing the two plastic push locks from behind
(gently push them out). Once these pieces are removed the ash tray, there
should be a screw or bolt in the back portion to remove. Gently pull the
center section off, there may be a screw behind the heater/cool controls
(can't remember). Good luck.
Tony
1995 Toyota Tacoma
K&N FIPK Gen. 2 - Throttle Body Spacer
Fiberglass fender flares
3" Fabtech Spindle lift
31" Tires
"JoeSpareBedroom" <dishborealis@yahoo.com> wrote in message
news:oP3Zg.3326$ya1.752@news02.roc.ny...[color=blue]
> "turboguns" <dragoon@yahoo.com> wrote in message
> news:g-SdnX3m69qoranYnZ2dnUVZ_sOdnZ2d@hawaiiantel.net...[color=green]
>> can anyone help me with the how to remove and replace my stereo in a 94
>> toyota pickup manual drive4x4 pick up? i have no idea where to start and
>> there is not many places that are willing to
>> install here for toyotas[/color]
> Where is "here"?
>[/color]
