Ideas on Failed Emissions - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-06-2006, 01:29 PM   #1 (permalink)
nfirtaps
Guest
Posts: n/a
View nfirtaps's Photo Gallery
Owner of (92 4WD Toyo Pickup 3.0L V6).
I just failed emissions and am trying to make my truck pass myself.
I have incredibly high CO and moderately high HC. Low NO.
I have done the following things:
1.) Pulled the oxygen sensor and tested it according to :
[url]http://www.unofficialbmw.com/all/engine/all_o2sensor.html[/url]
.... It passed. Also I have no check engine light with it connected.
2.) Verified no massive vacuum problems.
3.) Banged against my catalytic converter and heard no rattling.
What are some other things I should try?
Thanks,
Lloyd
Old 12-06-2006, 09:08 PM   #2 (permalink)
al
Guest
Posts: n/a
View al's Photo Gallery
Re: Ideas on Failed Emissions
Sure sounds like it's running rich. How do the plugs look? If one
plug looks more carbon fouled than the others you could have a bad
plug, ignition wire or distributor cap. I presume the engine
temperature is normal and not running cold as an open themostat could
cause the coolant to be cold enough to keep the mixture rich. Good
luck. Al
nfirtaps wrote:[color=blue]
> Thanks,
> Lloyd[/color]
Old 12-06-2006, 11:35 PM   #3 (permalink)
View toyomoho's Photo Gallery
Excessive CO usually results from rich air/fuel ratios. Check any items that can cause the engine to run rich.
High fuel pressure at injectors
Leaking fuel injector(s) including cold start injector (if you have one)
Gasoline in the crankcase
Plugged PCV valve or hose
Bad sensor(s) causing the ECU to drive the fuel/air mixture rich such as O2, coolant temp and throttle position sensor.
A higher HC may be due to misfire.
Might check the computer for codes, just in case the check engine light was not triggered.
Old 12-07-2006, 12:20 PM   #4 (permalink)
nfirtaps
Guest
Posts: n/a
toyomoho wrote:[color=blue]
> one)
> was not triggered.
> toyomoho
> toyomoho's Profile: [url]http://www.toyotanation.com/forum/member.php?userid=59151[/url]
> View this thread: [url]http://www.toyotanation.com/forum/showthread.php?t=169044[/url][/color]
Guys, thanks a lot for your replies, I will try all your suggestions.
BB code is Off
Smilies are Off
[IMG] code is Off
92 3VZ FE Failed Emissions !!!!? scprandy 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-31-2006 11:51 AM
Yaris failed emissions test androidGB Yaris, Vitz and Echo Forum 12 12-27-2005 01:30 AM
88 Camry Failed Emissions check - High N02 mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 12 09-08-2004 10:43 AM
i just failed emissions powderblue91 General Discussion 2 05-27-2004 12:21 AM
I FAILED emission! TRDragoon General Discussion 39 10-03-2003 12:17 AM
