5" mudflap clearance - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-11-2006, 01:30 PM   #1 (permalink)
Stumpy
Guest
Posts: n/a
View Stumpy's Photo Gallery
This isn't important, but I'm curious. The Tacoma Prerunner SR5 only has 5"
clearance between the front mudflap and the ground. I took it out on a very
primitive dirt road and it did fine for a 2WD truck. It sounded like I was
tearing up the bottom because the semi-rigid mudflaps scraped over most of
the obstacles.
I'm considering using some pliers and bending them up or even cutting them
back a little bit. The rear ones are much higher(shorter). I understand
the utility of big flaps, but I'm having a hard time ignoring the noise.
Anyone else modified flaps on a 95% highway vehicle?
Old 12-11-2006, 02:06 PM   #2 (permalink)
JoeSpareBedroom
Guest
Posts: n/a
View JoeSpareBedroom's Photo Gallery
Re: 5" mudflap clearance
"Stumpy" <perilmung@spamnet.con> wrote in message
news:Lshfh.8833$tM1.8090@newsread1.news.pas.earthlink.net...[color=blue]
> 5" clearance between the front mudflap and the ground. I took it out on a
> very primitive dirt road and it did fine for a 2WD truck. It sounded like
> I was tearing up the bottom because the semi-rigid mudflaps scraped over
> most of the obstacles.
>[/color]
When I see how little spray my Tacoma kicks up on a wet road, I figure the
people behind me are happier, so I leave the flaps alone.
BB code is Off
Smilies are Off
[IMG] code is Off
V6 Valve clearance adjustment v-cam Camry & Solara Lounge 3 04-26-2006 08:12 PM
valve clearance? 82toyo Pre-88 Toyota Pickup/Hilux 1 04-10-2006 04:52 PM
tC ground clearance with ground effect kit P1no12 1st Generation (2005-2010) 2 04-27-2005 08:37 PM
2005 Tacoma- poor ground clearance 2tacomas 2nd Generation (2005+) 18 12-22-2004 04:50 PM
