95 Taco Engine "sucking noise" - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-12-2006, 02:49 PM   #1 (permalink)
Steven Zeuner
Guest
Posts: n/a
View Steven Zeuner's Photo Gallery
Hi folks, don't know a ton about trucks but i've owned the tacoma since 1995
and never heard this noise before. It only sounds like its sucking some air
under acceleration. You can feather the gas on and off and hear the engine
"suck air" when the accelerator is pressed. I tried to narrow it down.
Sounds like its under the plenum or around the back right side.
Any ideas?
Thanks
Old 12-12-2006, 05:10 PM   #2 (permalink)
Dante
Guest
Posts: n/a
View Dante's Photo Gallery
Re: 95 Taco Engine "sucking noise"
Steven Zeuner wrote:[color=blue]
> Any ideas?
> Thanks
>[/color]
I have a 96 Tacoma and mine started something similar recently. It
started the same time that I cleaned my mass airflow sensor. After
doing a few things to diagnose, it sounds like it's coming from the
catalytic converter. I believe that something is broken inside the cat
and that is where the noise is coming from. As to why it started after
cleaning the mass airflow sensor... Maybe there is more airflow so the
sound is more pronounced. The sucking noise is not always there. The
cat also rattles quite a bit but I'm not sure if that's normal. Very
weird...
Dante
Old 12-14-2006, 01:13 AM   #3 (permalink)
mjsmikey
Guest
Posts: n/a
View mjsmikey's Photo Gallery
I could be something as simple as a Gasket, or a Broken Vacuum line.
Inspect Carefully, Vacuum leaks generally lead to idle problems, Brake
Booster Issues, and Odd Sucky Noices.
BB code is Off
Smilies are Off
[IMG] code is Off
Replacement engine for '95 4Runner?? mks 4Runner Lounge 8 12-04-2007 03:14 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 12:49 PM
Just purchased a new '07 LE (first post) with break-in procedures Forced Induxion 5th & 6th Generation (2002-2006 & 2007-2011) 9 07-17-2006 08:29 AM
Transmission for 95 4runner w/90 engine Mallenski 4Runner Lounge 0 03-13-2006 12:55 PM
Where to buy 95 tercel 5efe engine parts? reezytercel Tercel, Paseo, Starlet, and Sera Forum 3 09-17-2005 01:52 AM
