engine noise at start up - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-13-2006, 12:33 PM   #1 (permalink)
dan baker
Guest
Posts: n/a
View dan baker's Photo Gallery
ok this is the problem its 2.7 tac 133567 mile no smoke or leaks
when u start it up on a cold day or after 4 hrs later if u just let it
idle its fine but if u try to take off u get this knocking noise get
louder if u accelerate ore so my question is whats the sings of a
oil pump going out?? after it warm up the noise is gone even after u
drive an d restart it iam running 5-30 in it now should u go thicker
with the miles i have now could this have any thing to do with valve
adjustment?? i was told it would be about 487.0 0 for one is this true
that much please let me know
BAIN15
Old 12-13-2006, 05:52 PM   #2 (permalink)
tbuggle@yahoo.com
Guest
Posts: n/a
View tbuggle@yahoo.com's Photo Gallery
Re: engine noise at start up
mine does the same. been told it's a valve lifter, and until oil
pressure builds up, it knocks.
cold starts, especially in winter. usually only once a day, at first
startup.
i've been seeing/hearing this for 50-70k, with no problems. i have 195k
on it now.
no oil leaks, doesn't seem to use/burn oil, i hardly even check it
anymore.
i use 15-50 synthetic on advice from a "yota" friend, not sure if it's
correct but hasn't seemed to cause any probs.
never a single problem with the truck other than cracked exhaust
mainfold( replaced with a downey header) and a throttle sensor ($50
part).
I'll keep driving it til it dies but DO wonder if i should be doing a
timing chain at some point????.......
dan baker wrote:[color=blue]
> BAIN15[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
'98 Corolla engine noise earthmover Archived Corolla threads 5 10-28-2009 10:16 PM
Need Help - Noise from Front Driver's Side Engine Area at Idle TradeViceroy Camry & Solara Lounge 0 07-21-2006 01:10 AM
hot engine wont start but cold OK dejohn Camry & Solara Lounge 13 01-27-2006 02:29 PM
my Camry 03 makes loud noise from engine room! poraminna 5th & 6th Generation (2002-2006 & 2007-2011) 6 02-23-2005 10:19 PM
Worsening Noise In Engine lloydjv Celica Forum 2 02-09-2004 06:36 PM
