89' Pickup- Sometimes it Starts, Sometimes it Don't - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-15-2006, 03:36 PM   #1 (permalink)
Malcolm
Guest
Posts: n/a
View Malcolm's Photo Gallery
1989 Toyota Pup 2WD 4CYL- My truck will start 6 or 7 times without a
hitch and then I'll drive someplace and park and when I come back to
leave, the engine won't turn over. The battery is working, the guages
light up, the buzzer will sound if the door is open. But when I turn
the key in the ignition to crank it, nothing. The two times it has
happened recently, I let it sit for 1-6 hours, came back and it turned
over and cranked. No anomalies in the weather (rain, etc.) The one
similarity I noticed was that both incidents happened after the first
time I drove the vehicle and shut it off that particular day. Dealer of
course can't replicate the problem. Any suggestions?
Old 12-15-2006, 10:33 PM   #2 (permalink)
al
Guest
Posts: n/a
View al's Photo Gallery
Re: 89' Pickup- Sometimes it Starts, Sometimes it Don't
I'd try cleaning the battery terminals first. A poor connection can
allow enough current to turn on dash lights and chimes (a few amps) but
not turn the starter (a few hundred amps). Bad connections often get
worse when hot. Good luck. Al
Malcolm wrote:[color=blue]
> course can't replicate the problem. Any suggestions?[/color]
Old 12-16-2006, 07:29 AM   #3 (permalink)
ed_herman@yahoo.com
Guest
Posts: n/a
View ed_herman@yahoo.com's Photo Gallery
If cleaning the terminals does not help, sounds like the 'toyota
starter contact' problem. It is easy to repair after you get the
starter in your hands. The positive contact wears away until the
plunger cannot make good contact every time. Try
[url]http://www.4crawler.com/4x4/CheapTricks/Starter.shtml[/url]
Old 12-16-2006, 10:57 AM   #4 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Yup - starter contacts - cheap fix if you can do work yourself.
<ed_herman@yahoo.com> wrote in message
news:1166272162.740701.317210@j72g2000cwa.googlegroups.com...[color=blue]
>[/color]
Old 12-18-2006, 10:20 PM   #5 (permalink)
Malcolm
Guest
Posts: n/a
Thanks for the advice everyone!
Old 12-22-2006, 04:21 PM   #6 (permalink)
gordon507@telus.net
Guest
Posts: n/a
View gordon507@telus.net's Photo Gallery
> Thanks for the advice everyone![/color]
I have to same problem with my 1990 4x4 pu with the 22re engine. I have
check everything from the battery to the starter. I have replaced the
starter twice, replaced the battery. I thought it might of been the
clutch over ride switch so I bypasses it and a month later it did it
again. When i use a volt meter I found a voltge drop of 4 volts between
the battey and key switch. When i check the battery it self it reads
12.89 volts. Once I hook an jumper battery it starts okThis has been a
ongoing problem for 2 years now. What I have done now is installed a
bypass switch, so when It won't start I just push the switch and it
starts everytime.
Gordon
Old 12-22-2006, 06:18 PM   #7 (permalink)
Paul.
Guest
Posts: n/a
View Paul.'s Photo Gallery
A 4 volt drop between the battery and key switch is way too much!! You have
some bad connections somewhere that is degrading the electrical circuit.
Check both ground connections including under the bolts to the metal and the
positive wiring connections.
Re-hookup the safety switches before someone accidentally sends your truck
forward during startup.
Paul.
<gordon507@telus.net> wrote in message
news:1166822486.085971.53700@h40g2000cwb.googlegroups.com...[color=blue]
> Malcolm wrote:[color=green]
> starts everytime.
> Gordon
>[/color]
Old 12-22-2006, 08:11 PM   #8 (permalink)
Mike K
Guest
Posts: n/a
View Mike K's Photo Gallery
> starts everytime.
> Gordon
>[/color]
a few years ago I worked on a 22re, I don't remember the year. It had a bad
relay. the relay was under the dash near the steering column. the ign switch
and safety switches energized the relay, the relay sent power to the
starter.
Mike K
BB code is Off
Smilies are Off
[IMG] code is Off
89 toy pickup starts when cold then shuts off after warms up? D.Rosser 89-95 Toyota Pickup/Hilux 6 11-06-2006 09:16 PM
89 Pickup idles rough when warm Nybbles 89-95 Toyota Pickup/Hilux 10 07-22-2004 04:36 PM
body lift for 89 pickup w/automatic trans 89'TOY 89-95 Toyota Pickup/Hilux 4 07-13-2004 10:36 PM
