Help: Looking into purchasing a T Truck - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-16-2006, 01:37 PM   #1 (permalink)
Bette
Guest
Posts: n/a
View Bette's Photo Gallery
I have read some post and know if I post here you will be helpful.
My husband is ill and I will need a Toyota Truck for the winter
months.
I asked my son, but he prefers a Chevy.
Thanks so much. We have an avalon, but I would feel better driving a
truck.
Nothing fancy. Just something safe.
Bette
Old 12-16-2006, 02:10 PM   #2 (permalink)
Noon-Air
Guest
Posts: n/a
View Noon-Air's Photo Gallery
Re: Looking into purchasing a T Truck
thats real easy...you can get a pretty good deal on an '06 Tundra with a
regular cab, 2wd, V-6 and manual trans *if* you can find one.
Its a full size 3/4 ton truck, that should get you around 18 mpg.
"Bette" <bettebates@comcast.net> wrote in message
news:1166294234.266253.238190@73g2000cwn.googlegroups.com...[color=blue]
> months.
> truck.
> Bette
>[/color]
Old 12-16-2006, 03:19 PM   #3 (permalink)
Noon-Air
Guest
Posts: n/a
btw... a Tundra in that partitular configuration is considered by insurance
companies to be a "work truck", not a toy or a people toter so you will get
the lowest rates.
"Noon-Air" <Noon-Air@comcast.net> wrote in message
news:4eOdnaVqXc0u2RnYnZ2dnUVZ_vGinZ2d@comcast.com...[color=blue]
> news:1166294234.266253.238190@73g2000cwn.googlegroups.com...[color=green]
>> months.
>> truck.
>> Bette
>>[/color]
>[/color]
Old 12-16-2006, 03:23 PM   #4 (permalink)
Bette
Guest
Posts: n/a
Noon-Air wrote:[color=blue]
> the lowest rates.
> news:4eOdnaVqXc0u2RnYnZ2dnUVZ_vGinZ2d@comcast.com...[color=green]
> > Its a full size 3/4 ton truck, that should get you around 18 mpg.[/color][/color]
Thanks so much. My hubby has Parkinson's D. and is not bad yet, but I
don't want to be stuck in the Pa. hills when it snows.
Appreciate you reply.
Bette
Old 12-16-2006, 06:07 PM   #5 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Given your circumstance, ill husband and living in the hill country, might I
suggest you loos closely at something like the 4Runner? This is built on a
truck frame, and has the features of a truck, but is entirely enclosed. I
think that your husband will be needing some significant hardware to support
him soon, and having that stuff inside and out of the elements will prove to
be a benefit.
You did not mention that you need to haul stuff, so I assume your
requirement is for ground clearance, and perhaps the more upright seating
that a truck gives as opposed to a car. The 4Runner meets both of these
points, and provides greater comfort as compared to a truck.
Good luck,
> months.
> truck.
> Bette
>[/color]
Old 12-16-2006, 07:26 PM   #6 (permalink)
Bette
Guest
Posts: n/a
Jeff Strickland wrote:[color=blue]
> be a benefit.
> Good luck,[/color]
Thanks to all.
So far he is not wheelchair bound or using a walker, only a cane. It
will be some time before he is in serious health and being I am only
5'2" and he is over 6'2" I am not able to carry him over a snowy
mountain. *smiling* because it is my therapy.
Naturally, if we are expecting the "SNOWSTORM" of the century we remain
indoors.
Again thank you for your feedback.
Bette
Old 12-16-2006, 11:45 PM   #7 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Truck safe? Why would you think so? They have less safety equipment than
an SUV like 4Rnr/Rav4/Highlander. Plus unless you put weight in rear
traction isn't that good - 2WD is much worse than a front wheel drive car.
Why not try winter tires on your Avalon on a spare set of rims?
> months.
> truck.
> Bette
>[/color]
Old 12-17-2006, 12:55 AM   #8 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On 16 Dec 2006 16:26:30 -0800, "Bette" <bettebates@comcast.net> wrote:[color=blue]
>Jeff Strickland wrote:[/color]
[color=blue][color=green]
>> be a benefit.
>> points, and provides greater comfort as compared to a truck.[/color]
>indoors.[/color]
If you are indeed up in Snow Country I would suggest the standard
2WD truck with a Limited Slip Differential in the rear axle. If they
do not have any trucks in your area with them factory installed you
can get it installed at the dealer or an off-road supply shop for a
modest fee.
Having a LSD rear axle makes driving in snow a whole lot easier and
safer, it avoids the big problem that will get you stuck - without a
LSD if one rear wheel gets into mud or slush it will spin, and you
aren't moving. A regular "open" differential sends all the power to
the spinning tire.
With an LSD both of the rear wheels are pushing equally under power,
and one of the two will usually find some traction to get you going.
Driven properly you can go just as many places with a 2WD LSD truck
as a full 4X4 that costs a lot more. The only advantage of a 4X4 over
a 2WD with LSD is you'll get better resale value - and it's all in the
buyer perception.
Once you get the truck experiment with keeping some ballast weight
in the back - 200 to 400 pounds of "Miscellaneous Stuff" will do. For
a very slight fuel mileage penalty you will get a much smoother ride
on the highway, and better traction in the slushy stuff. Truck
suspensions are designed to ride best while you carry cargo, not be
totally empty.
Besides, you want at minimum a cross-bed toolbox or tonneau cover on
the truck with your emergency and survival supplies stored in it -
wool blankets, bottled water, granola bars, camp stove, a few days of
freeze-dried or canned foods, fire extinguisher, road flares for
signaling (and they make dandy fire starters too), motor oil, shovel,
tire chains, tow strap, jumper cables...
Sometimes you don't have any choice where you're at when that "Storm
of the Century" hits, so Plan B is the Boy Scouts "Be Prepared."
--<< Bruce >>--
Old 12-17-2006, 08:47 AM   #9 (permalink)
Bette
Guest
Posts: n/a
Bruce L. Bergman wrote:[color=blue]
> On 16 Dec 2006 16:26:30 -0800, "Bette" <bettebates@comcast.net> wrote:[color=green]
>[color=green][color=darkred]
> >> be a benefit.
> >indoors.[/color]
> modest fee.
> the spinning tire.
> buyer perception.
> totally empty.
> --<< Bruce >>--[/color]
Thank you both for your insight. I use to drive a little green pick up
truck years ago when I went deer hunting with our son and his buddies.
I was the only one who could field-dress a deer.
Now we are also looking into a vehicle that will be able to house a
wheelchair for my husband.
I want him home with me for as long as possible.
Bette
Old 12-17-2006, 02:07 PM   #10 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:1166315190.402420.184940@79g2000cws.googlegroups.com...[color=blue]
> Jeff Strickland wrote:[color=green]
>> might I
>> a
>> support
>> to
>> be a benefit.
>> Good luck,[/color]
> Thanks to all.
> indoors.
> Bette
>[/color]
Your stature is thje same whether you get a truck or the 4Runner. From the
perspective of your diminutive build, the vehicles are the same. the 4Runner
has its storage capacity inside the vehicle, wheras the truck's storage is
outside. Consider the 4Runner as opposed tot he truck, you get the same
features in terms of ground clearance and rugged nature, but you get more
refined features in the passenger arena.
Another consideration is the Sequoia. This is essentually a Tundra that is
enclosed in the back, much the same as the 4Runner is a Tacoma that is
enclosed. Less truck-like, but with ample ground clearance is the
Highlander. You can get the 4Runner and Sequoia in 4WD configurations, I'm
not sure of the Highlander.
Old 12-17-2006, 02:21 PM   #11 (permalink)
Noon-Air
Guest
Posts: n/a
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:1qmdnRa10p7ECBjYnZ2dnUVZ_qmpnZ2d@ez2.net...[color=blue]
> news:1166315190.402420.184940@79g2000cws.googlegroups.com...[color=green]
>> Jeff Strickland wrote:[color=darkred]
>>> might I
>>> a
>>> I
>>> support
>>> prove to
>>> be a benefit.
>>> seating
>>> Good luck,[/color]
>> Thanks to all.
>> indoors.
>> Bette
>>[/color]
> 4Runner has its storage capacity inside the vehicle, wheras the truck's
> storage is outside. Consider the 4Runner as opposed tot he truck, you get
> the same features in terms of ground clearance and rugged nature, but you
> get more refined features in the passenger arena.
> not sure of the Highlander.[/color]
You can also put a nice shell on a Tundra for a whole lot less than the
additional cost of a Sequoia, or 4-Runner
[url]http://new.photos.yahoo.com/noon_air/album/576460762351274650[/url]
Old 12-17-2006, 04:13 PM   #12 (permalink)
Bette
Guest
Posts: n/a
> news:1qmdnRa10p7ECBjYnZ2dnUVZ_qmpnZ2d@ez2.net...[color=green]
> > news:1166315190.402420.184940@79g2000cws.googlegroups.com...[color=darkred]
> >>> might I
> >>> a
> >>> I
> >>> support
> >>> prove to
> >>> be a benefit.
> >>> seating
> >>> Good luck,
> >> Thanks to all.
> >> indoors.
> >> Bette
> >>[/color]
> [url]http://new.photos.yahoo.com/noon_air/album/576460762351274650[/url][/color]
Once again, thank you for so much info.
Our son sent this to me a few moments ago.
[url]http://www.amsvans.com/?page=currentSpecials[/url]
The vans do come equipped with wheelchairs for his needs.
It's not so much the snow as his comfort getting in and out when things
become difficult.
Yet, snow is an issue; seeing I don't want to be in a situation where
we cannot get help.
Bette
Old 12-17-2006, 04:21 PM   #13 (permalink)
Noon-Air
Guest
Posts: n/a
news:1166390025.769764.91190@73g2000cwn.googlegroups.com...[color=blue]
> Noon-Air wrote:[color=green]
>> news:1qmdnRa10p7ECBjYnZ2dnUVZ_qmpnZ2d@ez2.net...[color=darkred]
>> >>> might I
>> >>> on
>> >>> a
>> >>> enclosed.
>> >>> I
>> >>> support
>> >>> prove to
>> >>> be a benefit.
>> >>> seating
>> >>> these
>> >>> Good luck,
>> >> Thanks to all.
>> >> remain
>> >> indoors.
>> >> Bette
>> > the
>> > get
>> > you
>> > is
>> > I'm
> become difficult.
> we cannot get help.
> Bette[/color]
Seems like they are real proud of those vans.... My Tundra with the custom
ordered shell, sliding window between the shell and cab, class III reciever
hitch, tax, title, license, was less than $19,000 after rebates.
Old 12-17-2006, 04:31 PM   #14 (permalink)
Bette
Guest
Posts: n/a
> news:1166390025.769764.91190@73g2000cwn.googlegroups.com...[color=green]
> > Noon-Air wrote:[color=darkred]
> >> >>> might I
> >> >>> on
> >> >>> a
> >> >>> enclosed.
> >> >>> I
> >> >>> support
> >> >>> prove to
> >> >>> be a benefit.
> >> >>> seating
> >> >>> these
> >> >>> Good luck,
> >> >> Thanks to all.
> >> >> remain
> >> >> indoors.
> >> >> Bette
> >> > the
> >> > get
> >> > you
> >> > is
> >> > I'm
> > become difficult.
> > we cannot get help.
> > Bette[/color]
> hitch, tax, title, license, was less than $19,000 after rebates[/color]
Gulp!!! Our son suggested if we purchase this in Delaware we will be
avoiding any state tax.
Then my sister mentioned that was illegal.
Bette
Old 12-17-2006, 05:11 PM   #15 (permalink)
Noon-Air
Guest
Posts: n/a
>> custom
>> reciever
> Bette
>[/color]
Did I mention that those vanes for $25K - $30K are all *USED*!!?????
My Tundra was new.
BB code is Off
Smilies are Off
[IMG] code is Off
Many of you guys seem curiously unaffected by gas mileage mattxwill 2nd Generation (2005+) 155 12-13-2010 04:18 PM
Taco tailgate...POS arctic_front 2nd Generation (2005+) 102 05-14-2010 08:26 PM
Would you purcahse another 05+ Tacoma naiou 2nd Generation (2005+) 114 07-01-2007 07:16 PM
NEW FRONTS IN THE GLOBAL AUTO WAR: Toyota launching attempt at dethroning the pickup RAV4EVR Toyota News 6 11-15-2006 02:16 PM
