1999 Tacoma Prerunner transmission slipping after timing belt repair !? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-21-2006, 05:25 AM   #1 (permalink)
ScottHW
Guest
Posts: n/a
View ScottHW's Photo Gallery
I took my 99 Tacoma 3.4L (96,000 miles) into the shop to have the
timing belt, water pump, and engine belts replaced. The timing belt
actually still looked pretty good, but the water pump was on the way
out, so good "timing" on that account. Anyway, the transmission
started slipping right away. I mean, it takes 2 or 3 seconds for it to
kick into gear after starting it and putting in fwd or reverse. It
improves after warming up but this is disturbing to say the least. it
wasn't doing this before the above mentioned repair. How could this
repair have affected the transmission ? I mean in the NORMAL course of
this repair ? I realize that an incompetent mechanic could screw up
most anything, but I just don't understand the connection, if any.
Thanks,
Scott
Old 12-21-2006, 06:29 AM   #2 (permalink)
ScottHW
Guest
Posts: n/a
Re: 1999 Tacoma Prerunner transmission slipping after timing belt repair !?
More detail:
1999 Toyota Truck Tacoma PreRunner Extra Cab 2WD V6-3.4L (5VZ-FE)
Has been well maintained according to factory schedule. Could this be
due an electrical control of some sort that was not put back correctly
and/or needs to be reset ?
Scott
Old 12-21-2006, 09:01 AM   #3 (permalink)
bbtaco
Guest
Posts: n/a
View bbtaco's Photo Gallery
"ScottHW" <scotthwnet-ng2007@yahoo.com> wrote in message
news:1166700560.487753.9590@73g2000cwn.googlegroups.com...[color=blue]
> More detail:
> Scott
>[/color]
Have you checked the fluid level recently? Has the transmission filter ever
been changed when the atf fluid was drained?
Old 12-21-2006, 09:45 AM   #4 (permalink)
ScottHW
Guest
Posts: n/a
Fluid level was the first thing I checked - it was fine (sorry I left
that out). As for filter, uncertain, at least not by me. I bought it
at 72,000 miles, the darn thing was in mint condition. Previous owner
said it had "transmission service" at 60,000, whatever that means.
I can imagine all sorts of things that COULD go wrong, its just so odd
that it was pronounced immediately after the mentioned repar.
Scott
bbtaco wrote:[color=blue]
> news:1166700560.487753.9590@73g2000cwn.googlegroups.com...[color=green]
> > More detail:
> > Scott
> >[/color]
> been changed when the atf fluid was drained?[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
2002 Tacoma Timing Belt replacement fajkus1 1st Generation (1995.5–2004) 12 12-30-2010 08:43 AM
Corolla VE 1999 need timing belt? skyline2k Introduce Yourself Here 4 05-26-2007 10:23 AM
Changine Timing Belt..Found Oil behind Timing Covers A2brb Camry & Solara Lounge 11 11-14-2005 05:10 PM
Does the 2003 Tacoma v6 have a timing chain or belt? Markmmg 1st Generation (1995.5–2004) 2 07-12-2003 02:53 PM
81 Celica and Timing Belt GregAt99 Celica Forum 3 05-10-2003 01:09 PM
