Re: 1990 4runner wont move:(
On Fri, 22 Dec 2006 13:29:09 -0500, [email]porshapower@webtv.net[/email] (:\) :\)) found
these unused words floating about:
[color=blue]
>I was on the highway yesterday and driving along when it started smoking
>and I pulled over and it wouldnt move anymore. I towed it home and
>transmission fluid is full but the level doesnt seem to move on the
>dipstick and the fluid is not getting hot no matter how long I let the
>truck sit running(I left it running for an hour in park). All the gears
>feel like neutral. I have revved it up in drive and reverse and low to
>see if it moved even a little but nothing. Its a v6 automatic. I have
>to press the button by the side of the shifter to disengage it from park
>because the switch that did it electronically when you pressed the brake
>no longer works...would this have anything to do with it?? Thanks:)[/color]
Have you looked to see if the linkage is moving from your shifter to the
transmission?
FWIW: Smoking - from where?
