2003 Highlander AC/Heat problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-23-2006, 03:17 PM   #1 (permalink)
thomaskblair
Guest
Posts: n/a
View thomaskblair's Photo Gallery
My 2003 highlander switches between AC to Heat constantly. It is acting
like the temperature controller is being moved between cold and hot every
few seconds.
Any ideas as to what I should check first?
Thanks
Old 12-23-2006, 04:22 PM   #2 (permalink)
Noon-Air
Guest
Posts: n/a
View Noon-Air's Photo Gallery
Re: 2003 Highlander AC/Heat problem
"thomaskblair" <thomaskblair@bellsouth.net> wrote in message
news:W8gjh.9623$cB6.8883@bignews7.bellsouth.net...[color=blue]
> few seconds.
> Any ideas as to what I should check first?[/color]
The Yellow Pages for a tech to straighten out the mess you made when you
tried to install that new thermostat you got from Home Depot.
Old 12-23-2006, 05:06 PM   #3 (permalink)
Noon-Air
Guest
Posts: n/a
"Noon-Air" <Noon-Air@comcast.net> wrote in message
news:LbKdnTe2uJmVAxDYnZ2dnUVZ_tijnZ2d@comcast.com...[color=blue]
> news:W8gjh.9623$cB6.8883@bignews7.bellsouth.net...[color=green]
>> few seconds.
> tried to install that new thermostat you got from Home Depot.[/color]
Oops... sorry... wrong group :-)
Old 12-24-2006, 02:37 AM   #4 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sat, 23 Dec 2006 16:06:01 -0600, "Noon-Air" <Noon-Air@comcast.net>
wrote:[color=blue]
>news:LbKdnTe2uJmVAxDYnZ2dnUVZ_tijnZ2d@comcast.com...[color=green]
>> news:W8gjh.9623$cB6.8883@bignews7.bellsouth.net...[/color][/color]
[color=blue][color=green][color=darkred]
>>> few seconds.
>>> Any ideas as to what I should check first?[/color][/color][/color]
First figure out exactly what's it's doing to give you the Hot-Cold
swings, then you can figure out how to cure it - Is the AC Compressor
running constantly, cycling on and off, or not running at all? Engine
temperature gauge steady of bouncing? Heater hoses hot (open heater
valve) or not? Can you see the heater valve linkage to tell whether
it is cycling? How about the blend doors, Heat/Defrost/Air door or
the Fresh/Recirc door?
My first thought is the radiator coolant level is way low, and you
have air pockets cutting the heat flow intermittently. If the cab
temperature control panel is sending signals to the AC compressor and
heater valve alternately, it could be the cabin temperature sensor is
bad and giving it a comfort temperature target that keeps moving...
Another thing that the dashboard controls like to do is get cold
solder joints between the circuit board and the potentiometers and
switches. If you can push on one corner of the Fan Speed Switch or
the Temperature Slider and everything returns to normal while you are
pushing, pull out the controls and resolder everything.
Give us a bit more to work with here.
>Oops... sorry... wrong group :-)[/color]
You are supposed to restrict the snarky one-liners to alt.hvac,
where the norm is to treat everyone like they're trying to take the
bread out of your mouth.
Over here, we try to give honest and useful answers... ;-P
--<< Bruce >>--
Old 12-24-2006, 08:05 AM   #5 (permalink)
thomaskblair
Guest
Posts: n/a
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:1caso299r22gkn5dvn8dmptji49capqv1t@4ax.com...[color=blue]
> wrote:[color=green]
>>news:LbKdnTe2uJmVAxDYnZ2dnUVZ_tijnZ2d@comcast.com...[color=darkred]
>>>> acting
>>>> every
>>>> few seconds.
>>> you
> --<< Bruce >>--
>[/color]
When this started the other day, whenever I turned the fan switch on, the
air was immediately hot, but if I turned the temperature control a 1/4 turn
toward heat and back to cold, the air would go back to being cold. The
constant change between hot and cold does not happen all the time, but the
above does.
Thanks for your help
Old 12-26-2006, 08:05 PM   #6 (permalink)
=?iso-8859-15?Q?Tekkie=AE?=
Guest
Posts: n/a
View =?iso-8859-15?Q?Tekkie=AE?='s Photo Gallery
Noon-Air posted for all of us...
[color=blue]
> > few seconds.
>[/color]
Wrong newsgroup there Nooner - ha ha ha
Tekkie Don't bother to thank me, I do this as a public service.
Old 12-30-2006, 12:52 PM   #7 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
"Noon-Air" <Noon-Air@comcast.net> wrote in message news:YqWdnQxmD7HUNRDYnZ2dnUVZ_uC3nZ2d@comcast.com...[color=blue]
> "Noon-Air" <Noon-Air@comcast.net> wrote in message news:LbKdnTe2uJmVAxDYnZ2dnUVZ_tijnZ2d@comcast.com...[color=green]
>> "thomaskblair" <thomaskblair@bellsouth.net> wrote in message news:W8gjh.9623$cB6.8883@bignews7.bellsouth.net...[color=darkred]
>>> My 2003 highlander switches between AC to Heat constantly. It is acting like the temperature controller is being moved between
>>> cold and hot every few seconds.
>> The Yellow Pages for a tech to straighten out the mess you made when you tried to install that new thermostat you got from Home
>> Depot.[/color]
>[/color]
LOL... the alt.HVAC newsgroup is beyond useless
BB code is Off
Smilies are Off
[IMG] code is Off
2003 camry door lock problem tdocamry 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-30-2011 06:32 PM
2003 Corolla Problem (Belt probably?) Jun118 Archived Corolla threads 4 07-04-2005 12:56 AM
Highlander 2003 A/C filter curley 1st Generation (2001–2007) 3 01-04-2005 07:17 PM
buying a used 2003 highlander webpilot 1st Generation (2001–2007) 5 11-04-2004 09:55 PM
2003 Corolla S Problem Fortis Archived Corolla threads 9 07-01-2002 03:53 PM
