What is proper procedure for servicing a 2000 Tunda Tranny? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-28-2006, 01:09 AM   #1 (permalink)
specman1@webtv.net
Guest
Posts: n/a
View specman1@webtv.net's Photo Gallery
I wanted to ask what is involved to do this? Do you have to drop the
pan, just drain the fluid and replace, is there a filter? My dealer only
does power flushes at 124 bucks and I have heard good and bad about
doing it this way. Might be something I don't want to tackle but wanted
to ask first.
Old 12-28-2006, 11:54 AM   #2 (permalink)
RefineryDog
Guest
Posts: n/a
View RefineryDog's Photo Gallery
Re: What is proper procedure for servicing a 2000 Tunda Tranny?
No filter - just drain and fill a couple of times using the right fluid -
without the power flush you will need to do it multiple times to get a full
swap of fluids.
You will only drain 4 quarts each time.
David
I'd rather die while I'm living than live while I'm dead!
Jimmy Buffett
<specman1@webtv.net> wrote in message
news:498-45935F87-2598@storefull-3334.bay.webtv.net...[color=blue]
> to ask first.
>[/color]
Old 12-28-2006, 08:35 PM   #3 (permalink)
al
Guest
Posts: n/a
View al's Photo Gallery
As long as the trans fluid looks good (original pink color, smells like
oil and not burnt plastic) a full flush is good long term insurance.
Yes it ain't cheap but consider what a tranny costs. Generic
recommendation is to do it every 24000 miles or two years. That's
conservative. You could get away with doing it somewhat less often.
But the key is that the fluid must look good. If the fluid is dark and
burnt, then leave it alone. Hope it helps. Al
[email]specman1@webtv.net[/email] wrote:[color=blue]
> to ask first.[/color]
Old 12-30-2006, 12:50 AM   #4 (permalink)
specman1@webtv.net
Guest
Posts: n/a
Yesterday I did just a basic fluid drain and refill. The owners manual
says it takes 2 quarts doing this but mine held 4 quarts. I noticed the
famous "clunk" when I go to stop now is gone. The fluid did not look
real dirty. Go figure.
Old 12-30-2006, 12:04 PM   #5 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sat, 30 Dec 2006 00:50:12 -0500, [email]specman1@webtv.net[/email] wrote:
[color=blue]
>real dirty. Go figure.[/color]
Was the car cold from sitting overnight? Some of the fluid that
would be inside the torque converter and the valve body of a warm
transmission drained back into the pan, nothing too unusual.
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
Proper engine wash procedure? kamrhee 3rd & 4th Generation (1992–1996 & 1997–2001) 23 01-22-2007 02:57 AM
2000 Camry Tranny slips occasionally at hwy speeds Morley 3rd & 4th Generation (1992–1996 & 1997–2001) 12 06-26-2006 03:59 AM
Proper H2 - H4 - L4 shift procedure. jedi 2nd Generation (2005+) 3 06-06-2005 07:35 PM
How to: Change tranny fluid? SmokeyWren 2nd Generation (2000-2004) 4 04-30-2005 12:51 AM
tranny time! racerhex Camry & Solara Lounge 30 07-23-2003 01:44 PM
