88 4Runner not getting gas. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-28-2006, 06:11 PM   #1 (permalink)
Harry
Guest
Posts: n/a
View Harry's Photo Gallery
I have an 88 4runner with a V-6 5-speed. It has been sitting for about 6
months since I started it last. Yeah, the gas is turning bad. In times
past after it had been setting, it would start on 4 or 5 cylinders and after
a few seconds would start hitting on all cylinders and run fine after that.
This time it will not fire unless I shoot it with starting fluid and it will
not keep running when the fluid is used up. I checked all the fuses that I
could find and they were good. It appears that I am not getting any fuel to
the fuel rail as I loosened the banjo fitting and there wasn't any gas there
to leak out.
Do I have to remove the tank to get to the pump? Where are the wires that
power the pump so I can see if I have voltage? Where should I check next?
Thanks to you all.
Old 12-29-2006, 03:19 PM   #2 (permalink)
ed_herman@yahoo.com
Guest
Posts: n/a
View ed_herman@yahoo.com's Photo Gallery
Re: 88 4Runner not getting gas.
There should be a connection in the diagnostic to make the fuel pump
run. Before that, check to see that the flapper on top of air filter
is moving - this controls when the pump runs after it starts. Good
luck. Ed
BB code is Off
Smilies are Off
[IMG] code is Off
Gas Boycott - A slightly different approach Tideland Prius Off Topic 6 08-27-2005 11:55 AM
gas price solution....maybe kliped Archived Corolla threads 6 08-23-2005 07:46 PM
Parting out 88 4Runner BillyBanana 4Runner Lounge 0 08-19-2004 11:07 PM
