'86 Toyota truck squeals when cold; only when driving - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 12-30-2006, 12:38 AM   #1 (permalink)
rruffrruff@yahoo.com
Guest
Posts: n/a
View rruffrruff@yahoo.com's Photo Gallery
I just acquired this truck from my parents with an actual 50k miles.
It's a 2wd extra cab SR5. It seems fine except for an odd squeal while
driving when the engine is cold. The sound isn't subtle. It is a fairly
high-pitched whine or squeal that warbles slightly at the frequency of
the driveshaft (I'm guessing). I can change it's tone and loudness by
varying the throttle... no noise when coasting. If I start the truck
and let it warm up for ~10 minutes, it doesn't make the noise at all...
normally it takes 2 or 3 miles for it to quiet down.
Any ideas? It doesn't make sense to me. If it was a belt or something
in the engine, it should make noise even when I'm not driving it. On
the other hand I don't understand why warming up the engine would
silence the drivetrain.
Thanks...
Old 12-30-2006, 08:47 AM   #2 (permalink)
Ernie Leimkuhler
Guest
Posts: n/a
View Ernie Leimkuhler's Photo Gallery
Re: '86 Toyota truck squeals when cold; only when driving
In article <1167457132.076981.248410@a3g2000cwd.googlegroups.com>,
[email]rruffrruff@yahoo.com[/email] wrote:
[color=blue]
> Thanks...[/color]
Belt squeel.
Try replacing the drive belts.
There are 2, they cost under $10 each.
If the belts don't fix the squeel, it can be the idler bearing on the
upper belt tensioner.
Old 12-30-2006, 01:26 PM   #3 (permalink)
Guest
Posts: n/a
Ernie Leimkuhler wrote:[color=blue]
> Belt squeel.
> upper belt tensioner.[/color]
I did increase the *tension* on the belts and it didn't help. It also
doesn't make sense to me that I'd need to be driving to make them
squeal. I can put it in D with the brake on and gun the engine, turn
the steering back and forth, and there is no noise. The truck needs to
be moving. I replaced an idler bearing on an '84 I used to have... it
wasn't sounding like this, though.
Yes, this is an automatic... forgot to mention that. Seems to shift
fine.
Old 12-30-2006, 08:05 PM   #4 (permalink)
TOM
Guest
Posts: n/a
View TOM's Photo Gallery
[email]rruffrruff@yahoo.com[/email] wrote:[color=blue]
> Ernie Leimkuhler wrote:[color=green]
>> Belt squeel.
> fine.[/color]
Does the squeal vary with speed, like maybe a disc brake pad?
Tom - Vista, CA
Old 12-30-2006, 10:35 PM   #5 (permalink)
Guest
Posts: n/a
TOM wrote:[color=blue]
> Does the squeal vary with speed, like maybe a disc brake pad?[/color]
I can vary the sound quite noticably by varying the throttle
application, but it isn't really speed dependent... plus there is no
noise when coasting, so I don't think that could be it.
BB code is Off
Smilies are Off
[IMG] code is Off
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 07:20 PM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 10:38 AM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 07:54 PM
problem starting '86 toyota truck catfish jerry Pre-88 Toyota Pickup/Hilux 1 10-10-2006 06:33 PM
