Re: 2005 Tundra oil change access
There is a refill plug on the side of the transmission. Drian plug is
referred to as the "overflow" plug. There is a procedure in the shop manual
on how to inspect and add fluid, requires shorting pins on a DLC, using the
shift lever to put the vehicle in a "fluid tempature detection mode" and
using the A/T Oil Temp Light as a guide when adding fluid. Fluid is a new
type - Toyota ATF WS.
"davidj92" <davidj92@sigecom.net> wrote in message
news:mJmdnQdjdsIjJYDfRVn-1A@sigecom.net...[color=blue]
> Rich Lockyer wrote:[color=green]
>> On Wed, 23 Feb 2005 07:34:41 -0600, "davidj92" <davidj92@sigecom.net>
>> wrote:
>>[color=darkred]
>>> Haven't messed with one of the sealed units but have heard of them
>>> recently. What if any is the recommended service on the sealed
>>> tranny? Can the fluid only be serviced via the cooling lines?[/color]
>> I would assume so. I have not seen one personally.
>> For now, it's a dealer service item, but it's considered a "lifetime"
>> fluid fill from the factory.
>>[/color]
> I haven't heard of the fluid being different so I don't see how they can
> do lifetime on fluid but, if we wait a couple years we'll find out for
> sure. :-)
>[/color]
