Automatic Brake Adjusters - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-04-2005, 11:54 PM   #1 (permalink)
Jerry
Guest
Posts: n/a
View Jerry's Photo Gallery
I put new brake shoes on my '85 Xtra Cab today. I had to turn the star
wheels all the way down to be able to put the drums over the hubs after I
put on the new shoes and now I don't have very much brake pedal and I have
to pull the parking brake out almost all the way to make it engage.
My neighbor (My mentor) said that the truck has automatic brake adjusters
and that after driving and repeated stopping that my brake pedal would
come back up to what it's supposed to be. He also said that I would have
to back up and when I hit the brakes that that's when the adjuster would
do it's adjusting.
Does this sound like the way these are supposed to work? I tried backing
up and braking about 10-15 times but it didn't seem to make any difference
in the amount of pedal or in the amount of distance I have to pull the
parking brake handle to make it work.
Did I do something wrong? Did I forget to do something that I'm supposed
to do?
Any info will be appreciated.
Thanks.
Jerry
Old 03-04-2005, 11:54 PM   #2 (permalink)
Toytruck
Guest
Posts: n/a
View Toytruck's Photo Gallery
Re: Automatic Brake Adjusters
You can pull out the emergency brake about a hundred times or you can
get under the truck and adjust the brakes from behind the wheel in
about 15 minutes.
Old 03-04-2005, 11:54 PM   #3 (permalink)
Scotty
Guest
Posts: n/a
View Scotty's Photo Gallery
I think that what he was trying to say is that some (most Ive found) auto
adjusters will tention up when you drive backwards with slight thottle
jabbing the brakes a few times while still slightly powering wheels. Dont
knwo exactly why but my ole man told me this and hes a mechanic. This works
mainly when you have brakes set close to what they should be not miles out.
Worth a trip or two down the driveway in reverse though eh.
"Toytruck" <t.greenfield@verizon.net> wrote in message
news:1109327145.643932.285810@g14g2000cwa.googlegroups.com...[color=blue]
> about 15 minutes.
>[/color]
Old 03-04-2005, 11:54 PM   #4 (permalink)
Robbo
Guest
Posts: n/a
View Robbo's Photo Gallery
I've found that "automatic brake adjusters" is one hell of an oxymoron, at
least for me it has been. I adjust them by hand instead of making myself
dizzy doing it the "normal" way. That's just me though, you may have better
luck than I getting them to adjust "automatically".
"Jerry" <jjones_0001@yahoo.com> wrote in message
news:JJwTd.5305$873.4644@newsread3.news.pas.earthlink.net...[color=blue]
> do it's adjusting.
> to do?
> Thanks.
> Jerry
>[/color]
Old 03-04-2005, 11:54 PM   #5 (permalink)
Ken Shelton
Guest
Posts: n/a
View Ken Shelton's Photo Gallery
Automatic brake adjusters work by one of two methods...while braking
during backing (not ahead), or by using the parking brake. My
Tundra has the parking brake linkage connected to the adjuster; I
don't know how they did it in '85. Did you see a connection between
the parking brake cable and some levers that worked the adjuster?
If so, get under the truck and pull the cable a coupl'a dozen times
on each side. You will hear it clicking as it adjusts. When it
stops clicking it is adjusted.
Or, do it the old way...turn the adjuster star wheel through the
port in the backing plate with an adjuster tool or screwdriver.
Ken
Jerry wrote:[color=blue]
> do it's adjusting.
> to do?
> Thanks.
> Jerry
>[/color]
Old 03-04-2005, 11:54 PM   #6 (permalink)
Ferrunner
Guest
Posts: n/a
View Ferrunner's Photo Gallery
Scotty wrote this:
[color=blue]
> works mainly when you have brakes set close to what they should be not
> miles out.[/color]
Toyota doesn't work this way. The first three messages should have been a
clue.
One problem I had with my drums was a lip around the outside edge that
made the drums a pain to remove and reinstall. Took a die grinder to
that, fortunately there was not much needed to remove.
If the lip is too high, perhaps the shoes have to be super loose to get
the drum on. Or perhaps the shoes were not properly seated when the OP
finished the install. Either way, go through the backplate and turn the
star wheel for best results.
Old 03-04-2005, 11:54 PM   #7 (permalink)
Guest
Posts: n/a
View 's Photo Gallery
To my knowledge, you will have either "star adjusters" or automatic
adjusters.You will not have both.You have star adjusters (as I do on my 86).
These may be adjusted by removing the rubber access plugs on the brake
backing plate so that you can adjust the "star" with 2 screwdrivers.Your
truck does not have automatic adjusters that your neighbor spoke of.Auto
adjusters utilize a small ratchet which will click to the next level when
you back up and then brake firmly.
Todd
Old 03-04-2005, 11:54 PM   #8 (permalink)
Guest
Posts: n/a
Todd
> do it's adjusting.
> to do?
> Thanks.
> Jerry
>[/color]
Old 03-04-2005, 11:54 PM   #9 (permalink)
Toytruck
Guest
Posts: n/a
[email]twiedeman@dslextreme.com[/email] wrote:[color=blue]
> adjusters.You will not have both.You have star adjusters (as I do on[/color]
my 86).[color=blue]
> These may be adjusted by removing the rubber access plugs on the[/color]
brake[color=blue]
> backing plate so that you can adjust the "star" with 2[/color]
screwdrivers.Your[color=blue]
> truck does not have automatic adjusters that your neighbor spoke[/color]
of.Auto[color=blue]
> adjusters utilize a small ratchet which will click to the next level[/color]
when[color=blue]
> Todd[/color]
All drum brakes have star adjustors. And all that I am aware of have
"automatic" adjustments operated by backing up or the parking brake.
Old 03-04-2005, 11:54 PM   #10 (permalink)
Guest
Posts: n/a
View : \)'s Photo Gallery
FYI, the original VW Beetle, with drum brakes, had star adjusters, but they
weren't automatic. Every once in a while, you'd need to get into the drum
to take up some slack.
news:1109420506.019935.170070@f14g2000cwb.googlegroups.com...[color=blue]
> [email]twiedeman@dslextreme.com[/email] wrote:[color=green]
> my 86).[color=green]
> brake[color=green]
> screwdrivers.Your[color=green]
> of.Auto[color=green]
> when[color=green]
>> Todd[/color]
>[/color]
Old 03-04-2005, 11:54 PM   #11 (permalink)
Dan G
Guest
Posts: n/a
View Dan G's Photo Gallery
You haven't adjusted brakes till you've done all 4 wheels on an old
Landcruiser with dual-cylinder shoes.
": )" <none@none.net> wrote in message
news:Ho5Ud.33250$Tj7.6550@twister.socal.rr.com...[color=blue]
> FYI, the original VW Beetle, with drum brakes, had star adjusters, but[/color]
they[color=blue]
> news:1109420506.019935.170070@f14g2000cwb.googlegroups.com...[color=green]
> > [email]twiedeman@dslextreme.com[/email] wrote:[color=darkred]
> > my 86).[color=darkred]
> > brake[color=darkred]
> > screwdrivers.Your[color=darkred]
> > of.Auto[color=darkred]
> > when[color=darkred]
> >> Todd[/color]
> >[/color]
>[/color]
Old 03-04-2005, 11:54 PM   #12 (permalink)
JayW
Guest
Posts: n/a
View JayW's Photo Gallery
Not sure about the automatic adjust, but if your brake pedal goes to the
floor, it sounds to me like you need to bleed the brakes. Good luck.
> do it's adjusting.
> to do?
> Thanks.
> Jerry
>[/color]
Old 03-04-2005, 11:54 PM   #13 (permalink)
TOM
Guest
Posts: n/a
View TOM's Photo Gallery
JayW wrote:[color=blue]
> floor, it sounds to me like you need to bleed the brakes. Good luck.[/color]
This kind of reminds me of the mechanic that told the car owner: "We
couldn't fix your brakes, so we made your horn louder."
Tom - Vista, CA
Old 03-22-2005, 12:25 PM   #14 (permalink)
speedy
Guest
Posts: n/a
View speedy's Photo Gallery
Unfortunately what you describe is for US made cars. All the Japanses
machines I have worked on use the parking brake to adjust the rear shoes.
-Pete
Scotty wrote:
[color=blue]
>[color=green]
>>about 15 minutes.
>>[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
