99 tacoma elec problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 03-04-2005, 11:54 PM   #1 (permalink)
patrick mitchel
Guest
Posts: n/a
View patrick mitchel's Photo Gallery
Have a 99 tacoma that popped a turn bulb (driver side) yesterday. Got the
replacement bulb, installed and the turn signal fuse blew. Replaced the fuse
(10 amp) and that blew as well. Took the bulb out, tried the next fuse with
the RIGHT turn signal activated, no problem. Yet when the LEFT turn signal
with the bulb in is tried, the fuse blew again. Then , I tried to start the
truck...NADA- not even the click of the bendix. Left the light on for a
while to check the batery- shows 12.10 volts. 2 unrelated problems??? or
interrelated problem? TIA Pat- whose glad he still has the 85 toy as a
backup..
Old 03-09-2005, 01:30 AM   #2 (permalink)
Chad E. Carlson
Guest
Posts: n/a
View Chad E. Carlson's Photo Gallery
Re: 99 tacoma elec problems
I had a similar issue (may or may not be related to the issue you describe)
on my 2000 Tacoma. Turns out there was a faulty module of some sort in the
left rear of the vehicle. I think it was related to the tow light setup.
When I replaced the fuse, I noticed smoke coming from the lamp housing - and
immediately pulled the fuse. Toyota replaced the module, wiring, etc.at no
charge because it was covered under a recall issued for the 2000 model year.
I don't know if this will help you, but thought I would share *just in
case*.
Cheers!
"There's no place like 127.0.0.1"
"patrick mitchel" <patm317@hotmail.com> wrote in message
news:38m7quF5pdeheU1@individual.net...[color=blue]
> fuse
> with
> the
> backup..
>[/color]
Old 03-09-2005, 08:26 AM   #3 (permalink)
patrick mitchel
Guest
Posts: n/a
Turns out the problems were created by my own haste to replace the blown
turn signal bulb. It's possible to put the bayonet bulb in 90 degrees out
(that is the 2 prongs are pushed into the slots cut for the copper
contacts).The result was I deformed the central contact enough to
permanently force in to touch the other contact even after removing the bulb
and installing it correctly. I checked all the circuit and finally figured
out that I was still getting a shorted circuit without the bulb being
installed.I managed to trace it to the bulb holder, did some prying on the
contacts and managed to realign the contacts , back to the norm after
installing a new hazard/horn fuse as well as the turn signal signal fuse.
Best intentions pave the road to hell..... Pat
BB code is Off
Smilies are Off
[IMG] code is Off
