Re: Best Break-In Oil for Rebuilt Tranny?
DeepDiver wrote:[color=blue]
> I have an '89 Toyota Pickup w/ 22RE engine and W56 5-speed manual
> transmission. I am replacing the tranny with a rebuilt unit from Marlin
> Crawler. I'd like to run Red Line MT-90 transmission oil in it, but feel I
> should use a cheaper oil for an initial break-in period. I realize that
> rebuilt transmissions don't require extensive break-in because the gears
> have already been broken in, but the synchros and bearings are new, plus it
> will allow me to flush out any dirt or grit that got into the tranny during
> the rebuild.
> Here's the problem, most of the auto shops seem to only carry 75W-90 GL-5
> gear oil with EP additives for use in hypoid differentials, as if that's a
> one-size-fits-all lubricant. I've read that oil with hypoid EP additives can
> make shifting hard (and accelerate wear) because it's too slippery for the
> synchros to effectively mesh.
> Any recommendations on a brand/grade oil to use and how long I should keep
> it in before switching to the Red Line oil?
> Thanks,
> Michael
>[/color]
The problem with some GL-5 differential gear oils in a synchromesh
transmission is that sulfur-based extreme pressure agents cause
damage to yellow metals, bronze, brass, in the transmission. Some
newer formulations of GL-5 gear oils are dual-rated for GL-4 and do
not damage yellow metals.
Or, find your own GL-4 gear oil at an auto parts store and fill with
that.
Specialty Formulations is a new boutique blender of lubes that is
equal to Red Line and has some products that work in situations
where Red Line isn't the best. You might take a look at their products.
[url]http://www.specialtyformulations.com/index_files/Page457.htm[/url]
Ken
