Re: '97 Camry 3-CD Changer Error Sign E-02
On Fri, 22 Apr 2005 14:33:47 -0400, "BOBBYZ" <bobbyz@epix.net> wrote:
[color=blue]
>HELLO EVERYBODY. I have a '97 camry with a 3 cd in dash changer. The
>magazine is lodged in the deck but it's in the "change" or "outward"
>position (not inside the deck in the playing position). Does not work. I
>keep getting Error Sign E02. Can anyone tell me how to fix the problem.
>Thanks.
>BOBBYZ[/color]
I had a old Sony 10-disc changer that used to get confused where it
was in the load/unload cartridge cycle and freak with error messages.
The solution was often to remove ALL power sources for several minutes
and let it go through all the 'reset' checks when it powered up from
dead. It would then figure out that it had a cartridge halfway
ejected and either suck it in or finish spitting it out.
If that fails, you may have to take it out of the dashboard and
CAREFULLY extract the cartridge with hand tools. If you can, try to
get all the gears into either the 'cartridge fully out' or 'cartridge
fully in' position through spinning the drive motor with a pencil tip,
and watch for any jamming or "sticktion" in the gears and tracks.
Then apply power and let it try resetting itself.
If it has anything mechanically broken inside, it's either send it
in for factory service (where the little elves have access to the Top
Secret repair instructions and parts) or junk the radio and buy
another. The little gears and piece parts are usually not available
separately for more than a few years, and even then are a bloody
fortune and a pain for an outsider to order.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
