Re: EPC help!
On 2005-04-24, Joseph Wind <jpg@gif.com> wrote:[color=blue]
> What OS are you running? Under Win98 you could create a Ram Drive, install
> it that drive and then copy the installed directory to your HD, before you
> power down. If your running XP or Win2K, check to see if you have any
> unallocated space on your HD, if not, you could mount a smaller drive, USB,
> or flash drive, depending on how much space you need.
> Sounds like a DOS program, in most cases, XP and Win2K will not run
> properly.[/color]
That's sad. It should run under linux and DOSEMU though.
[color=blue]
> "Bugdude" <Bugdude.1ny1gb@no-mx.forums.yourdomain.com.au> wrote in message
> news:Bugdude.1ny1gb@no-mx.forums.yourdomain.com.au...[color=green]
>> I have douwnloaded the EPC from Yankee toys and I am unable to get them
>> to load onto my computer. I have a 20 gig hard drive and the setup
>> wizzard keeps telling me that there is not enough room. I have tried
>> the instructions that are listed at Yankee Toys but no luck. these in
>> fact...
>> "The EPC program is very old which means it does not understand todays
>> massive hard drives. There are two solutions to this problem.
>> First, you
>> can copy random data to your hard disk into a temporary folder until
>> the error
>> goes away. You can delete the data after you install the program."
>> I guess what I am needing is more specific instructions...step by step
>> if you would.
>> Thanks.
>> Bugdude
>> Bugdude's Profile:[/color]
> [url]http://www.toyotanation.com/forum/member.php?userid=28008[/url][color=green]
>> View this thread: [url]http://www.toyotanation.com/forum/showthread.php?t=76084[/url]
>>[/color]
>[/color]
