22RE - problem - H2O in #2 cylinder and oil - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 04-26-2005, 11:22 PM   #1 (permalink)
frankzao
Guest
Posts: n/a
View frankzao's Photo Gallery
Has any one had this problem and know how to fix it or what is going
on?
I’ve got a 92 pickup with a 22RE motor. I just rebuilt the entire
motor (bearings pistons chain head etc). I started the rebuild b/c I
was getting H2O out the tail pipe from what I thought was a blown
headgasket. I had everything redone and tested; ei the block and head
and valves. Now it is all back together and I have the SAME
problem........ It is running great no CEL, idles perfect, just I’m
getting coolant into the exhaust.
any ideas????????
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-22RE-problem-H2O-cylinder-oil-ftopict117493.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=570066[/url]
Old 04-27-2005, 12:03 AM   #2 (permalink)
hothead
Guest
Posts: n/a
View hothead's Photo Gallery
Re: 22RE - problem - H2O in #2 cylinder and oil
"frankzao" wrote:[color=blue]
> going on?
> I've got a 92 pickup with a 22RE motor. I just rebuilt the
> entire motor (bearings pistons chain head etc). I started the
> rebuild b/c I was getting H2O out the tail pipe from what I
> thought was a blown headgasket. I had everything redone and
> tested; ei the block and head and valves. Now it is all back
> together and I have the SAME problem........ It is running
> great no CEL, idles perfect, just I'm getting coolant into the
> exhaust.
> any ideas????????[/color]
is it a new head casting or reman, if reman may have crack in head,
also pull head and look for water marks in cylinder wall. have seen
cylinder sleeve cracking. look at intake manifold where water feed is
at, possible crack between intake runner and water port. double check
cylinder head flatness with a straight egde, last but not least look
at timing cover have also seen where loose chain has eaten through
cover at water ports and will leak into oiling system. the only real
diagnosis is to pull and inspect. good luck.
Old 04-27-2005, 12:03 AM   #3 (permalink)
frankzao
Guest
Posts: n/a
Re: Re: 22RE - problem - H2O in #2 cylinder and oil
"hothead" wrote:[color=blue]
> head, also pull head and look for water marks in cylinder
> wall. have seen cylinder sleeve cracking. look at intake
> manifold where water feed is at, possible crack between intake
> runner and water port. double check cylinder head flatness
> with a straight egde, last but not least look at timing cover
> have also seen where loose chain has eaten through cover at
> diagnosis is to pull and inspect. good luck.[/color]
The head was tested twice and is good.
The block was also tested and is good. One cylinder wall was damaged
so I had it resleeved.
The timing chain cover was also checked and is good.
The only thing left is the intake manifold.
The intake manifold looks good. No one can test it, but there are no
visable cracks between the intake runner and the water port.
Is it possible one of the water inlets into the manifold has an
internal leak?
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
[url]http://www.usenet.com[/url]
Old 04-27-2005, 11:05 AM   #4 (permalink)
Mark and Ellen Smith
Guest
Posts: n/a
View Mark and Ellen Smith's Photo Gallery
>[color=blue]
> I've got a 92 pickup with a 22RE motor. I just rebuilt the entire
> problem........ It is running great no CEL, idles perfect, just I'm
> any ideas????????
>[/color]
Have you retorqued the head bolts since the rebuild?
Mark
Old 04-28-2005, 12:04 AM   #5 (permalink)
hothead
Guest
Posts: n/a
> going on?
> exhaust.
check to make sure you dont have a cooling system hose where a vacuum
hose should be, ie recheck vacuum routing. had one in here six months
ago that customer had rebuilt and by mistake had croosed a hose.
BB code is Off
Smilies are Off
[IMG] code is Off
