Lubricaton for squeaky clutch pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 04-27-2005, 01:35 PM   #1 (permalink)
Swissguy
Guest
Posts: n/a
View Swissguy's Photo Gallery
I've got a squeaky clutch pedal that still squeaks regardless of what
lubrication I use on it. From what I'm seeing its where the spring
meets the arm of the pedal (not from the cylynder behind it). I've
used every lubricant under the sun (teflon based (white lightning),
silicon based, as well as the generic stuff (but not WD-40). Whatever
I use, the squeak is silenced for a week or two but then it returns.
ANy thoughts? What does toyota spec for this area?
Old 05-01-2005, 07:05 PM   #2 (permalink)
scott and barb
Guest
Posts: n/a
View scott and barb's Photo Gallery
Re: Lubricaton for squeaky clutch pedal
Probably the clutch cylinder is making the noise...
"Swissguy" <zehnderm@hotmail.com> wrote in message
news:1114623303.268666.25070@g14g2000cwa.googlegroups.com...[color=blue]
>[/color]
Old 05-05-2005, 12:06 AM   #3 (permalink)
dissembler
Guest
Posts: n/a
View dissembler's Photo Gallery
could be this...................
[url]http://www.lieblweb.com/tacoma/Mechanical/ClutchPedal/ClutchBushing.htm[/url]
Old 06-12-2005, 12:51 PM   #4 (permalink)
Captain Volume
Guest
Posts: n/a
View Captain Volume's Photo Gallery
"scott and barb" <crowley9@gate.net.> wrote in message
news:_gdde.3254$V01.2905@newsread1.news.atl.earthlink.net...
[color=blue]
> Probably the clutch cylinder is making the noise...[/color]
It is best to check this out. Mine ('87 Tac. 22R 4spd) squeaked without
relent. Tried everything I could think of. Then I found oil on the carpet.
The clutch master cylinder had suffered a failure of the rear seal on the
actuator shaft. This led to a change-out of the master cylinder, thus
eliminating the problem.
Hope this helps.
[color=blue]
> news:1114623303.268666.25070@g14g2000cwa.googlegroups.com...[/color]
[color=blue][color=green]
> >[/color]
>[/color]
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
[url]http://www.newsfeeds.com[/url] The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old 01-12-2006, 09:44 PM   #5 (permalink)
n
Guest
Posts: n/a
View n's Photo Gallery
Just lube the clutch spring with Penilube and it shpuld be good for some
time.
Remo
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
