Re: What's The Secret??? (Addendum) (Addendum to Addendum)
On Wed, 04 May 2005 19:57:21 GMT, [email]jjones_0001@yahoo.com[/email] (Jerry) wrote:
[color=blue]
>Okay. I found the jackhandle, crank and hole in the bumper but I can only
>turn the crank about a 1/4 turn either direction and I can't see above the
>tire to be able to get in there to lubricate the mechanism. Any
>suggestions on what to do next?
>jj[/color]
It's deliberately stiff cranking - there's a spring-loaded catch on
the handle part of the hanger winch, so the spare doesn't unwind and
drop down by itself. It should unwind counter-clockwise but whichever
way you get it moving, it will drop.
After the tire is down, you can easily get to the mechanism to
lubricate it.
And WD40 is NOT a long-term lubricant, it's Stoddard Solvent and
Kerosene - good for cleaning out the nasty crap, then you go for final
clean with brake cleaner, let that evaporate, and lubricate it. Use
something like white lithium grease in the gears.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
