Keep blowing out my high beams - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-22-2005, 06:21 PM   #1 (permalink)
O.B.
Guest
Posts: n/a
View O.B.'s Photo Gallery
I'm now on my 3rd set of halogen headlight bulbs for a 1984 Toyota
truck. It still uses the conventional H4 wiring. However, after about
a month of driving, the high beam filaments break (verified by measuring
continuity on the bulb). The low beams are just fine.
Any clue as to what is causing the high beams to die prematurely?
Old 06-23-2005, 01:01 AM   #2 (permalink)
Axel Hammer
Guest
Posts: n/a
View Axel Hammer's Photo Gallery
Re: Keep blowing out my high beams
"O.B." schrieb:
[color=blue]
> Any clue as to what is causing the high beams to die prematurely?[/color]
Strange.
I only can guess if you have a slight higher voltage or vibration is killing
them.
You may try to use bulbs with higher power (have a thicker filament) or some
of them vibration resistant ones.
Both may be found in agricultural shops (which I recommend for many useful
things on our 4x4s :)
Axel
BB code is Off
Smilies are Off
[IMG] code is Off
