'86 22re starting problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-26-2005, 11:29 AM   #1 (permalink)
nebwest2
Guest
Posts: n/a
View nebwest2's Photo Gallery
I have an '86 4wd p/u with the 22re, 137,000 miles. It runs like a top
but the initial (cold) start takes multiple tries. It will cough and
sputter, and stall for the first 2-4 attempts to start, then suddely
will kick in and as soon as it warms up a little it is good to go from
there on out. Once warm it will restart no problem. I suspected the
cold start injector or time switch, so I replaced them. However, I live
in AZ and a "cold start" right now is in 85 degrees. I would think it
would be able to start in those temps without the CSI. I tried jumping
the fuel pump test connector with the CSI removed from the intake
manifold so i could see if its flowing fuel and it isn't, but I think
it's too warm and it probably shouldn't be. Should it? The fuel pump
is running and there is fuel under pressure coming to the injector. The
resistance values for the injector and switch check out. When it was
colder out (60 Brrrrrr) I was having times when it wouldn't start at
all. It would just crank. Once it warmed up in the afternoon it would
start just fine. It's almost as if there is no fuel at the engine until
you crank for a while. I did try jumping the test connector for the fuel
pump, let it run for a few seconds and then try to start. it didn't seem
to make any difference. Sure does sound like a CSI problem doesn't it.
Recent work has included a new TPS which failed. I replaced it and set
it as per the fsm instructions and it seems to be working fine. The
timing chain was replaced. New alternator, thermostat, water pump,
belts, hoses, fan clutch, etc.
Any ideas?
I
nebwest2
nebwest2's Profile: [url]http://www.usenetcars.com/member.php?userid=2693[/url]
View this thread: [url]http://www.usenetcars.com/showthread.php?t=391483[/url]
Old 06-28-2005, 10:48 AM   #2 (permalink)
Kevin
Guest
Posts: n/a
View Kevin's Photo Gallery
Re: '86 22re starting problems
Same problem with mine...
86 1 Ton 22RE, auto trans.
I pulled the cold start injector and cleaned it with throttle body
cleaner; didn't help.
Kevin
Old 06-28-2005, 02:39 PM   #3 (permalink)
Kevin
Guest
Posts: n/a
Kevin here, one more thing.
If I pump the accellerator while cranking it usually fires up OK after
about 3-4 revolutions. Idle doesn't seem to be all that high when it
starts, but the engine doesn't stall.
For you gurus out there, if I had a check valve problem, would it take
more than 3-4 cranks to get fuel up to the injectors? I'm still
suspecting a cold start timer switch or injector problem.
Any advice is greatly appreciated.
Kevin
BB code is Off
Smilies are Off
[IMG] code is Off
