unable to open doors - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 06-27-2005, 02:03 PM   #1 (permalink)
ms_j
Guest
Posts: n/a
View ms_j's Photo Gallery
i locked my keys in my 1991 toyota pickup. while i was asleep my friend
proceeded to retrieve them by prying his way into the truck. he succeeded.
now i cannot open my doors from the inside or outside. the locks don't work
or the windows. can someone please tell me what to do?
Old 06-27-2005, 11:43 PM   #2 (permalink)
Tom
Guest
Posts: n/a
View Tom's Photo Gallery
Re: unable to open doors
Are they (the windows, locks) electric or manual?
On Mon, 27 Jun 2005 14:03:36 -0400, "ms_j" <bootsie_2@hotmail.com>
wrote:
[color=blue]
>or the windows. can someone please tell me what to do?[/color]
Old 06-28-2005, 03:42 AM   #3 (permalink)
Eddie
Guest
Posts: n/a
View Eddie's Photo Gallery
Find a new friend. I suggest the zoo. Most things there have more
brains then your current friend.
Sounds like he totaly screwed up the inside guts of your doors. If he
also bent them by trying to pry them open, then I suggest you hit a
salvage yard for a used set of doors.
It's not THAT hard to unlock it. I locked my keys in mine last week. After
spending 20 minutes with a slimjim, I said screw it, bent a welding rod
into the shape I needed, and pop, door open in less then 5 minutes.
On Mon, 27 Jun 2005 11:03:36 -0700, ms_j wrote:
[color=blue]
> succeeded. now i cannot open my doors from the inside or outside. the
> locks don't work or the windows. can someone please tell me what to do?[/color]
Old 06-28-2005, 03:42 AM   #4 (permalink)
Eddie
Guest
Posts: n/a
[color=blue]
Old 06-28-2005, 04:18 PM   #5 (permalink)
Joseph Wind
Guest
Posts: n/a
View Joseph Wind's Photo Gallery
Your friend might have screwed up the internals of the window and door lock.
It should be easy to fix if your mechanically inclined. You'll have to
remove the door panel, then carefully remove the weather seal. I said
careful, because you'll have to put it back. You can now look inside the
door to see what your friend screwed up. Any good mechanic worth their salt
should be able to fix it.
If you have window cranks, there is a trick to remove the clip holding the
crank, if you don't have the right tool. Let me know and I'll post it.
Is the key lock still useable?
Good luck!
JW
"ms_j" <bootsie_2@hotmail.com> wrote in message
news:8959d5edaee4c6367ecff773f30ca376@localhost.talkaboutautos.com...[color=blue]
> now i cannot open my doors from the inside or outside. the locks don't[/color]
work[color=blue]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
