Hi all, I am new to groups but am in desperate need of some help. I
have a 2001 Tacoma which I love to death. I recently bought chrome
power sideview mirrors to replace the factory black ones. Installation
was very easy however oce they were hooked up the right and down power
controls stopped working. I contacted the vedor who sold me the
mirrors and they are going to replace them. When I removed the chrome
mirrors and re-installed the factory black mirrors I had the same
problem, they move up and left, but not right or down. Does anyone
have any knowledge regarding this? Any troubleshooting help and or
tips would be very helpful. Thank all you experts in advance.
Do you hear the servo motors when you try to control the mirrors? If so you
might have popped out the link joint to the mirror itself. I've had to
replace just the mirrors and not he housing before.
"Jesse" <jmowen@adelphia.net> wrote in message
news:1120135287.951324.274230@g47g2000cwa.googlegroups.com...[color=blue]
>[/color]
i hear the motors and like i said they move up and left, just not right
or down. last night i ruled out the possibility of it being a fuse or
loose connection. my only guess now is that it may be the switch
itself. if i order teh switch thru Toyota it's about $120 and if that
is not the answer i'm stuck with the switch, no refunds...
Jesse wrote:[color=blue]
> right or down. last night i ruled out the possibility of it being a
> fuse or loose connection. my only guess now is that it may be the
> switch itself. if i order teh switch thru Toyota it's about $120 and
> if that is not the answer i'm stuck with the switch, no refunds...[/color]
If you move the switch and hear a motor running then it's not the switch. If
this isn't the case then before you purchase a new switch see if the switch
is repairable. I've taken many switches apart and cleaned contacts with
either a steel (not sandpaper type) emery board (for fingernails) or a
points file. Sometimes you can spray contact/switch cleaner through a hole
in switch housing to clean contacts too. One other option is to try to jump
across proper terminals to see if mirror motors work to eliminate switch.
Email me if you need schematics or wiring information and I'll look in the
service manuals I've got for 97 Camry and 01 Tundra for electric schematics
on switch and motor. They should be close enough to get a good working
knowledge of wiring.
HTH, davidj92
Do you hear the motors when you move right or down? Did you cut or unplug
any connectors during to swap? Sound like a short or a contact not closing
the circuit. If you have a voltmeter check the switch first then have
someone press the control while you check the mirror end. If you can remove
the switch you can check to see if it's the problem.
A fuse would provide power to the entire system. So if the fuse is blown,
the up and left would not work.
BTW you did not mention if this problem affected both mirrors.
news:1120232582.612240.323830@f14g2000cwb.googlegroups.com...[color=blue]
>[/color]
Thanks a lot David. To clarify, I hear the motor when they move up or
right, no sound when I push right or down. I have some QD electrical
cleaner, with your advise i will try to clen the switch adn see what,
if anything happens. Since I am new to groups, I do not see your
e-mail address but love more troubleshooting advise from you. thanks
again.
Thank you Joseph. The problem is effecting both mirrors the same. And
we did try to check the switch and wires with what I assume was a
voltmeter (a tool which you ground then test the wires with a seperate
tool that lights up) and got a reading as if there was no power to the
mirrors at all. I may be doing something wrong and any advise would be
great. Thanks again
> again.[/color]
If you are using Outlook or Outlook Express there are two buttons on the
top, one is "Reply Group" which will post an answer to the ng and the other
is "Reply" which will send an email to the poster's registered email
address. You have to watch as many people will use a fake address or one
with characters that have to be removed before it's a valid email address.
From what you say and what you posted in the reply to Joseph Wind I'd say
you probably have a bad switch. You might find one at a salvage yard, try to
find one that at least guarentees agains DOA.
HTH, davidj92
On 5 Jul 2005 10:01:08 -0700, "Jesse" <jmowen@adelphia.net> wrote:
[color=blue]
>great. Thanks again[/color]
Be advised that the mirror adjusting switch is likely a pair of
DPDT-CO (double-pole double-throw, center-off) switches, where there
is no power or ground at all on either of the motor leads if the
switch is not being pushed.
When you push the UP switch the motor gets +12V on one lead, and
ground on the other, to make the motor runs clockwise and the gears
make the mirror go up. And when you push the DOWN switch the same
up/down motor gets the opposite, the lead that was +12V for up is now
ground, and vice versa on the other - the motor runs counter-clockwise
and the gears push the mirror down.
Same thing with left and right - same DPDT-CO contacts, just
connected to a different motor and set of gears. And the selector for
adjusting either the left or right side mirrors with one 'joystick'
switch is a 4PDT arrangement sending the power and ground leads to the
correct motors on either side.
The switch might be sending the +12V to the motor when you push the
button, but if you don't have a ground connection from the motor going
back through the switch to a solid chassis ground nothing will move.
A little sleuthing with a test light or voltmeter will pinpoint the
trouble spot.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Thanks a lot Bruce, very helpful. I just found a 2003 Camry switch
which looks exaclty the same as the one in my Tacoma, I'm going to try
that and will let you all know what happens. Once again I thank you
all for your help with this. It's very frustrating when you have a
problem and the only people that will help you want to charge you a
million dollars. You guys are awesome!
Looking at a 2001 Highlander remote control mirror wiring diagram,
there should be positive voltage at terminal 6 (red wire with a black
stripe) when the switch is at the down or right position. If you have
the switch out, there should be continuity between terminal 8 (gray
wire) and terminal 6.
If the motors run in one direction but not the other, the problem
points to the switch. I can send you the Highlander wiring diagram is
you want.
Paul.
> million dollars. You guys are awesome![/color]
I bought a replacement switch for a 2003 Camry on e-bay for $11.00
shipped, compared to Toyota price of $130.00. The switch worked great
and my mirrors are back in action! Thanks again to everyone for their
help.
