87 hilux pickup broken rear wheel stud - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.trucks
alt.autos.toyota.trucks Toyota Trucks discussion newsgroup.
Old 07-03-2005, 05:35 PM   #1 (permalink)
Tinpotlocal
Guest
Posts: n/a
View Tinpotlocal's Photo Gallery
Not managed to get my hands dirty on this one yet but id just thought id
ask.
87 hilux 4x4 pickup, broken wheel stud in the rear (drum brake)
its sheared straight level with the wheel.
can these be replaced seperately? or am i going to have to break the bank
open.
how easy is it to do?
ta all
Old 07-03-2005, 09:49 PM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: 87 hilux pickup broken rear wheel stud
On Sun, 3 Jul 2005 22:35:57 +0100, "Tinpotlocal" <none@nohome.com>
wrote:
[color=blue]
>ask.
>open.
>how easy is it to do?[/color]
If you are careful, you can do them yourself. If you are lucky, you
can blame the broken stud on the last mechanic or tire shop that
worked on the car and let THEM change it. ;-) They probably have the
right tool and an assortment drawer full of replacement studs.
Most wheel studs have knurled shafts and are pressed into the hub
from the back side, and you can change them on the car IF you have the
right tools to press out the remains of the old stud, and pull the new
one into position.
If you don't have the tool you should remove the hub and use a shop
press to get the old stud stub out. If you beat on the hub (on the
car) with a hammer & punch, you'll probably wreck the wheel bearings -
not right away, but they'll go bad in a few weeks or months from the
little dents you'll make in the bearing rollers and races.
The new stud can be pulled into a clean hole in the hub very simply
with a lug nut, the hand lug wrench, a few flat washers, and a chunk
of steel pipe that slides over the stud, cut to the right length. Do
NOT use an impact wrench, you don't want to snap the new stud off.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 07-04-2005, 03:35 AM   #3 (permalink)
SnoMan
Guest
Posts: n/a
View SnoMan's Photo Gallery
"" wrote:[color=blue]
> thought id
> ask.
> brake)
> break the bank
> open.
> ta all[/color]
Generally these studs are just pressed in. You can drive them out with
the proper sized drift/punch and a few good whacks with a hammer.
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-87-hilux-pickup-broken-rear-wheel-stud-ftopict127316.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=620915[/url]
Old 07-04-2005, 03:36 AM   #4 (permalink)
SnoMan
Guest
Posts: n/a
Re: Re: 87 hilux pickup broken rear wheel stud
"Bruce L. Bergman" wrote:[color=blue]
> If you don’t have the tool you should remove the hub and use a
>shop
>car) with a hammer & punch, you’ll probably wreck the wheel
>bearings -
>not right away, but they’ll go bad in a few weeks or months from
>the
>little dents you’ll make in the bearing rollers and races.
>[/color]
Strange, I have never had that problem at all. If you use the right
size punch and a 2 lb or 3 lbs hammer they will pop right out with but
a few whacks. If you find yourself beating on it with no result it is
because you are not using the right hammer and/or punch to do the job.
There is not need to make this into a bigger job than it is.
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=621014[/url]
Old 07-09-2005, 12:59 AM   #5 (permalink)
Guest
Posts: n/a
View : \)'s Photo Gallery
replacing the broken lug stud is a piece of cake. 1st, remove the wheel and
brake drum. then use a hammer to strike the stud. more than likely there's
about a 1/4" or more of the broken stud sticking out of the axle. if it is
flush with the axle, then you'll need to use a punch. once the stud is
dislodged from the axle, remove it and insert the new stud. if you have a
basic lug nut (no chrome cap), place it backwards (cone side out) on the new
stud and use an impact gun to pull the stud into place.
"SnoMan" <UseLinkToEmail@AutoForumz.com> wrote in message
news:1_620915_4d36aa97b9dcbf83abac97a9445d63ec@autoforumz.com...[color=blue]
> "" wrote:[color=green]
> > thought id
> > ask.
> > brake)
> > break the bank
> > open.
> > ta all[/color]
> Topic URL:
> [url]http://www.autoforumz.com/eform.php?p=620915[/url][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
