Re: Flywheel resurfaceing?
"" wrote:[color=blue]
> Guys,
> I am in the process of putting a new Kevlar clutch in my
> 4runner. 94,
> V6. I am wondering if the flywheel should be resurfaced or
> not.
> it looks undamagd. You can still see the groves from turning
> but they
> are very smoothed out from the old clutch. No damage visible
> on the
> wheel...
> The manufacturer of the clutch says to grind the flywheel....
> but soes
> anybody do that? arent they usually turned?
> Should the flywheel be super smooth or rough?
> Oh and what a PITA it is to replace the crank seal.
> How does one take out the oilpan? This is a HUGE PITA .. had
> to drop
> the diff, but dont knwo how to get the pan back in :( Any
> ideas?
> Couldnt get the steering stuff off to slip the oilpan through
> the front
> Matt[/color]
It sounds okay to me but you could break the glaze of the flywheel
with some 120 grit sand paper if you want to. I have mixed opinions of
some of this exoic clutch because they do not engage and play the same
as a stock clutch. When I need more cluch, I go to a bigger diameter
stock style clutch and/or a stronger pressure plate too.
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/Toyota-Flywheel-resurfaceing-ftopict127373.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=621203[/url]
